A12/Dellorto
G'day,
I was wondering if anyone is or have ran a 45 dellorto with the A12?
Is it better to run twin 40 or single 45?
Any info would be much appreciated.
Cheers
Posted on: 2014/2/12 6:35
Re: A12/Dellorto
Twins are always slightly better.
For a stock A12, tune it with 28mm venturis. 45s
won't accept venturis that small. Use either a single 40 or twin 40s.
For a 7000 rpm A12, use 32 mm venturis. They are available for 40s or 45s.
Posted on: 2014/2/12 7:42
Re: A12/Dellorto
doofer wrote:
G'day,
Cheers
Is your A12 stock standard or modified (gx head? Race camshaft? Etc...)
I have seen a single 45 used frequently on A12 race motors.
Posted on: 2014/2/12 8:59
Re: A12/Dellorto
From Perth
Whats the cam specs
Posted on: 2014/2/12 10:38
Re: A12/Dellorto
Twin 35's choked to 30 or 32 would be fantastic on a plain or moderate A12.
But yes, more info would get some more accurate responses.
Posted on: 2014/2/13 0:55
Re: A12/Dellorto
I would go 40 regardless of single or double, my single 45 on my a12 that's got 10 thou flat tops lightened flywheel h89 head with oversize ports and valves extractors inch an 3/4 exhaust and a mild wade cam still runs stupidly rich and chews juice like no tomorrow, in saying that it runs fairly smooth, is always a bit seedy until warm as they all are.
From memory I have 28 or 30 chokes I believ. Cannot remember for the life of me why mains and secondary's...
Posted on: 2014/2/13 5:07
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: A12/Dellorto
Dellorto no longer sells 30 chokes for DHLA 45.
The 40s let you tune them for a mild A12 or a wild A12.
Posted on: 2014/2/13 5:16
Re: A12/Dellorto
From Sydney
The chokes have more influence over the mixture velocity flowing into the chamber. Your idle jet will have the most influence over your mixture at light throttle and progression to main jet fed full throttle.
Book in some time on the dyno or install one of those AEM A/F ratio gauges and see whats happening.
Posted on: 2014/2/13 6:43
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: A12/Dellorto
It's a stock motor but i'm planning on working it slightly. Not sure which way to go about it but a 45 was offered to me at a reasonable price. Quote:
datsunbeginner wrote:
doofer wrote:
G'day,
Cheers
Posted on: 2014/2/14 5:41
Re: A12/Dellorto
it's dead stock. I'm starting to collect parts and I came across a 45. I think twin 40's would be the go instead. Thinking of making it mild as it will be more of a cruiser.
Posted on: 2014/2/14 5:44
