« 1 2 (3)
Re: alternator overcharging
From vic
Hi so i got another regulator from the wreckers and it does exatcly the same thing charge light wont come on when ignition is on and when you start it the charge lught turns on amd glows brighter according to engine rpm
This is the 3rd regulator know 2 new 1 used so i think i can rule thenregulator out as a problem??
Ive checked the wiring and cant find anything wrong with it
Also i realised all the regulators have 6wires but the harness on the car has two wires missing whats the other two on the regulator for?
Thanks
Posted on: 2014/2/22 22:47
From Sydney, Australia
The regulator needs to match the alternator.
The lucas regulator is a small aluminium finned thing.
The other one has a huge block regulator.
Posted on: 2014/2/22 23:30
From vic
Yer mines the fairly large type with a rectangle connector
Posted on: 2014/2/22 23:45
Sounds like a real problem. What are the colors of the wires that have been cut out of the harness?
Posted on: 2014/2/22 23:54
« 1 2 (3)
