Browsing this Thread:
2 Anonymous Users
Re: my new ride 1200 ute |
Great progress. On the matter of clearance I'd be really interested to know the distance from the back of the Cam/rocker covers to the firewall using the Kev Rowley crossmember.
Are you going to run a heater...or don't you need one up there ?
Posted on: 2014/2/23 3:13
Quite a regular
From Cairns, Far North QLD, Australia
Looks brilliant!
Posted on: 2014/2/23 11:51
From Port Douglas. QLD
cadet I'll measure it when I get it bolted down. it seems to sit a bit further forward than others I have seen.
No heater..12v hair dryers for mod plate:) ...and no cold idle either.
Posted on: 2014/2/24 1:44
1200 ute ca18det
took a while but automatic pilot bush finally out. Motor should be in next week!
Posted on: 2014/3/4 10:25
1200 ute ca18det
Motor and gearbox in. Gearbox mount is 1inch out from where the l20 was. Still fits the original hole though. pics to come
Posted on: 2014/3/15 9:41
1200 ute ca18det
So it cleared your existing clutch master cylinder OK?
Keen to see pics and also keen to get some measurements off you from engine to firewall using the K.Rowley X-Member.
Posted on: 2014/3/16 0:22
Nice stuff
Posted on: 2014/3/16 3:41
had to remove clutch master to install. We installed the gbox attached to motor otherwise it would have stayed in. Plenty of room. I'll measure up for u tonight..
Posted on: 2014/3/16 5:13
1200 ute ca18det
just measured. engine is 4.5cm or 1.7inches from firewall
Posted on: 2014/3/16 6:43
1200 ute ca18det
motor and gbox in
Posted on: 2014/3/23 10:02
1200 ute ca18det
