« 1 ... 5 6 7 (8) 9 10 11 ... 15 »
Re: a15 block mazda head
Not too shy to talk
From corowa nsw
hi guys the head I used was a 1300 and had smaller valves . the 1600 head may have a clearance problem. haven't tried a 1500 so don't know if they hit. got some front plates almost done. only have 3 head gaskets
Posted on: 2014/2/2 10:21
From Malaysia
arent the tension side of the belt supposed to be straight and untensioned? i never saw an engine with tensioned tension side. all ive seen is straight belt or chain.
Posted on: 2014/2/2 10:23
BAT engine (A series tri-cam hybrid)
When I placed the headgasket from a 1600 head onto my A12 all seems good just need 2 and 3 bores offset machined inward to clear one inlet valve at worst a little nothing will do the job just like the big valve headed A series heads.
Anyways good news is Ive been informed the kits are ready to go, these took a long time to sort out and you get all the hard work done and sorted by the pioneer when you buy this kit which just covers the time and a little on the side for the effort.
You will need to bore for your A12 for 76mm daihatsu pistons for the HD or HC series engines or use the stock Mazda b series pistons for the A14 and A15 blocks.
Im building my first twin cam A series with the Daihatsu pistons, using the copper/composite gasket already to go, the block mods are just on the water and oil galleries, the seals are supplied for the camshaft and crank areas, you use your stock sump, rework some water galleries on the head, tap and insert some brass fitting to drain the oil from the head to the distributor cavity. Use megajolt junior or other crankfire ignition system for carbs or stock mazda ecu for all the injection from factory.
Will put up a more detailed description for those purchasing the kit
for now there are 3 kits available I have my name on the 4th so please
contact me if you would like to purchase the kit and so I can work out
postage cost to your door etc.
The price of the kits are 900aud for the front plate which also includes
cam and crank cover also camshaft drive attachment that uses the factory
mazda cam belt pulleys. The headgasket to suit 76mm bores is 160 aud.
It could possibly fit 77mm bores but will need to be remade for 78mm however
all the work has been done by the designer for you and is a great price for
using it as a template for when you get more made at your local gasket maker.
Please also consider the maker of this kit was asked as a favor to make these
for everyone here and he is only getting a small profit for his time/materials.
He doesnt have a business or internet to speak of and I will help anyone with
questions or technicalities that you might ask.
With 10.5:1 compression, dual exhaust camshafts ground from factory 235 degree
and 8.5 mm lift exhaust cams to 260 degree and 9.5mm lift, 2mm shaven B6 head
with aftermarket headers and quad 45mm bike carbs or 45mm efi tbs there is
160hp available at the wheels as done by countless Miata/Mx5 peeps.
Thats way more than any GX head can make as a daily which is what these mazda
machines are making reliably day in day out.
The belt driven aspect also saves some rotating weight from the chain drive
and the A series crankshaft is lighter than the Mazda full counteweight units
and should therefore spin up a little faster through the revvs all else being
equal and the A series timing cover is longer needed.
Pic below shows 2 front covers and a HG as you can see the sump extension lid
or cover has been tig welded so peeps can use stock sump with no mods.
More pics to come from other side but takes time as my fossil style phone takes
quite an effort to move the pics onto the pc.
For now Ill call this hybrid the BAT engine
eg. B for Mazda B series head, A for Nissan A series, T triple cams :)
Worth noting for a bit of history Cosworth/Lotus used the Kent motor in the
same configuration with the OHV camshaft to drive oil pump etc.
more pics of earlier pages
http://datsun1200.com/modules/newbb/v ... ASC&type=&mode=0&start=10
jpg  twincamAseries.jpg (71.78 KB)
737_530d85dd664f5.jpg 733X511 px
Posted on: 2014/2/26 6:01
Edited by D on 2014/2/26 6:24:18
Edited by D on 2014/2/26 6:26:21
For the USA and Canadian peeps earlier interested, I can arrange freight to you or one of you so you can save money and you will only need one head gasket to use or keep as reference for more locally your way.
Rowland makes these manifolds for webers for the B series head
M016 sells for172AUD and postage airmail is 64AUD, have stock
accepts Visa, Master and PayPal regards Rowland
http://datsun1200.com/uploads/newbb/737_528f605a04b0d.jpg
and technotuning the billet version for eage tbi's
https://technotoytuning.com/mazda/na18 ... 4ag-throttles-18l-na-head
Im aiming for this look but using Z head w/ webers or bike carbs
http://datsun1200.com/uploads/newbb/737_5266861935b6c.jpg
http://www.youtube.com/watch?v=5kiqvp63bTU
Posted on: 2014/2/26 6:32
Edited by D on 2014/2/26 12:52:38
If I had a series id be tempted selling my kidney for something like thus.
Great effort by the pioneer.
Posted on: 2014/2/26 6:51
From Townsville, Qld
How thick are these heads? would standard head bolts and arp head studs for the A series work?
I love this build, if some more money comes my way I might just have to have a go at it.
Posted on: 2014/2/26 8:08
Rob can answer that
jpg  BAT front cover block side.jpg (25.00 KB)
737_530de30071cdb.jpg 640X480 px
jpg  BAT front shot.jpg (34.05 KB)
737_530de30a1ef74.jpg 640X480 px
jpg  BAT sump view.jpg (30.56 KB)
737_530de31673719.jpg 640X480 px
Posted on: 2014/2/26 11:41
Edited by D on 2014/2/26 12:50:32
Edited by D on 2020/2/10 12:09:30
As you can see alot of work done to make a front cover
Posted on: 2014/2/26 12:53
Not too shy to talk
From corowa nsw
head bolts are not standard a series I went to a bolt place and got some hi ten bolts
Posted on: 2014/2/27 8:58
From Perth
The old cam is only running the oil pump and fuel pump right ?
So if I want a front cover with no old cam drive as I'm using a dry sump and electric fuel pump is that possible ?
Is it the upper or lower idler thats adjustable... since one of those will get the flick too
Posted on: 2014/2/27 11:30
