« 1 (2) 3 »
Re: Water pump cover plates - EOI
From Adelaide
Another thought, fuel pump block plates may be useful to some as well. That's something else I've been procrastinating on making.
Going off on a longer tangent, what do you reckon some aluminium laser cut frames might look like for the tail light assemblies? Sit some glass/ plastic behind and some appropriately coloured LEDs.
Posted on: 2012/6/28 9:09
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Cheers. Lamb. I'm putting the final touches on the drawing for the water pump plate and will have it finished and ready to cut very soon.
Fuel pump plates...Not a bad idea either. I will have to get my hands on a spare pump and make a drawing for that too.
As far as tail lights are we talking ute/coupe/sedan? I reckon it would be a little bit of a hassle cutting the plate and then bending it to suit. But I am open to trying.
Posted on: 2012/6/28 9:22
From Adelaide
I was thinking of Coupe tail lights since they mount flat. May not look any good but a thought worth playing with.
With any luck the fuel pump block off would suit other cars to.
Posted on: 2012/6/28 21:23
Ok guys got them on order at the laser cutter. Should be ready soon :)
Posted on: 2012/7/22 14:04
Well its been a year and half and I finally got a finished product. I have two pieces at the moment. I would like someone to volunteer installing one and test if there is any leaks. Anyone willing to try for me?
It's only 2mm Stainless steel. I wanted 5mm alloy but I guess they ran out of sheet or something got lost in the communication. These were thrown in for free with my last order of side vents so I am just asking for someone to try them out for fitment before I mass produce them. ( I am dattoless at the moment )
Cheers.
jpg  waterpumpcover.jpg (150.45 KB)
13419_53280cabc9cfc.jpg 600X427 px
Posted on: 2014/3/18 9:07
Re: Water pump cover plates - Volunteer needed!
From Perth
Keen on one when they are ready
No running car atm so can't help with the R+D though
Posted on: 2014/3/18 9:41
From Adelaide
I have a running car and keep needing to drop the coolant for various jobs but I would guess someone closer to home is a better option if you're after a quick result. My gut feel is the 2mm plate wont be stiff enough.
Posted on: 2014/3/18 20:49
I'm in oz temporarily. I suspect you are right that it is not thick enough. If you are keen lamb PM me your address. I really just need to confirm it fits well and fully covers the pump area, screw holes line up etc.... not sure whether tube gasket sealer or a paper gasket is the way to go.
You will get a free finished plate for helping out....when they are finished
Posted on: 2014/3/19 7:51
From Logan, QLD
2mm stainless is fine. Should have used ally tho.
Posted on: 2014/3/19 9:41
From Melbourne, Australia
2mm will be fine in steel, maybe 3mm for aluminium
bi-metal corrosion may be a problem with stainless
i will try the plate on a spare motor if you like
will PM my address and you can send it to me if it's easiest
Posted on: 2014/3/19 11:28
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
« 1 (2) 3 »
