A13 tall block wanted
Hi new to this site .Hope someone in the USA or Canada can lead me to an A13A Block 1288 cc Bare block or short is fine 73mm bore 77mm stroke. Many regards Tony Having trouble finding how to load to Classified
Posted on: 2014/3/21 8:39
Re: A13 tall block wanted
you can sleeve down an a14 from 76 to 73mm and use the stock a14 77mm stroke crank at worst?
Posted on: 2014/3/21 12:22
The A13 was made for; be year only, the 1974 model year (from May 1973). Which means they are not plentiful.
Keep watching eBay and searching Google for Craigslist ads. I see an A13 about one a year.
Or fit an A14. Its a direct replacement.
Another option is to buy a 1974 B210, remove the engine and sell the rest of the car for $100 scrap.
Posted on: 2014/3/21 19:26
also try and contact PJZ,a member on this forum from US.Has alot of racing parts for 1200s.
Posted on: 2014/3/21 22:37
I agree .Issue I have is the racing rules the engine has to less than 1340cc at manufacture.Hence am wanting longer stroke and con rod for Torque advantage on dirt .Seems A13 acute to US.Canada only one year 1974.I am in New Zealand.
jpg  Wellington Jan 2012.jpg (54.02 KB)
17722_532ccabae8246.jpg 588X405 px
Posted on: 2014/3/21 23:27
It is a cubic inch advantage compared to A12.
There is a small torque advantage compared to normal Asia-market A13.
Posted on: 2014/3/21 23:56
Currently using A12 70 mm stroke 78mm bore = 0.100 to water. 500 lift cam.CP Custom pistons 13.5 cr,Have had to relieve block to get exhaust valve in.My theory is at this compression ratio with 7mm longer stroke longer con rod will increase tdc dwell time to get a better bang on the Methanol. The short stroke engines tried here havent had enough torque of the turns ie Fiats, 4k etc. I Currently rev to 7800.We are 0.5 secs of the E13 pace that are pulling 9500 rpm. Your thoughts appreciated.
Cheers Tony
Posted on: 2014/3/22 2:50
7800 vs 9500 rpm and only 0.5 secs off awesome A12/13! A14 crank is all you need in sleeved down A12 block, I agree PJZ has the A14 and heaps of what you need.
Posted on: 2014/3/22 3:44
a12 stroker? a14/a15 crank and rods??
Posted on: 2014/3/22 8:43
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Thanks . Due to my not understanding how to contact,or advised people that may have what I want. If not to much trouble could you guys pls forward a request for a A13a tall block to a possible result .As this is what I require to develop this concept . I should be able to find crank here.I have shipping agent here ect. I know its a big call to find one but if dont ask wont get.At the end of the day I wish to exhaust the absoulte an A series can give rather than give up.After spending over $5000 on Cyl head development you would all understand.
Thanks for your patience with me. Cheers Tony
Posted on: 2014/3/22 9:04
