(1) 2 3 »
Crankshaft Big End Diameter?
From Los Angeles,CA
Does anyone know what the A14 Crank Big End Diameter is supposed to be? You know, where the rear crank seal runs. Also, the diameter of the FS5W60A main drive gear where the front oil seal runs.... These are both leaking badly even though they're both correct and brand new...
Posted on: 2014/4/13 3:45
Re: Crankshaft Big End Diameter?
From Central coast NSW
Hey lowtech u will find over time u end up with a groove in the shaft where the lip of the seal runs, if u can move the seal in a bit further it should seal again or try a speedy sleeve...
Posted on: 2014/4/13 4:37
From Los Angeles,CA
Thanks for the reply but there is no groove, it's a fresh motor. I didn't measure it because it wasn't scored, but it didn't look machined. I am thinking now that it must have been machined undersized at sometime. I'd like to verify what size it should be versus what it is.
Posted on: 2014/4/13 5:53
From Hawaii, USA
It is supposed to be 60 mm
The crankshaft big end is not supposed to be machined, at least Nissan didn't/doesn't have oversized seals.
12279-H2301 is for all A12/A14/A14 engines.
specifications
* Shaft Size 60 mm
* Housing Bore 82 mm
* Seal Outer Diameter 82.2 mm
* Seal Width 12 mm
Posted on: 2014/4/13 7:17
Edited by ddgonzal on 2014/4/15 5:50:12
FS5W60A front oil seal
From Hawaii, USA
32114-Y4000 Front Cover Oil Seal
* 60-series, including 4-speed and 5-speeds
* 71B-series
* 71C-series
Specs
* shaft size: 30 mm
* bore size: 45 mm
* seal outer diameter: 45.2 mm
* seal width: 8 mm
National 1981
Timken 1981
Nissan 32114-Y4000
Posted on: 2014/4/13 8:13
Re: FS5W60A front oil seal
From Stone Age somewhere in U.S.A.
Why not put a seal sleeve on it? For those who don't know, it's a thin steel band that goes over the worn seal surface and restores it to as new. It's a whole lot easier than replacing the part, and a lot less expensive. Timken makes one their part number is KWK99235. I'm sure that others make one also.
Posted on: 2014/4/14 16:43
From Los Angeles,CA
Yes thanks, I've already got one. I just want to verify that this is the problem. The stupid engine's already been out twice now for inspection. I want to make sure that this is the last time.
P.S. Thanks for the info DD!
Posted on: 2014/4/15 7:43
From Melbored
Probably best try the seal sleeve on the front and see if it cures it before taking the engine out, that way at least you know the front seal doesnt work then you pull the engine out to check the crank and go from there etc.
Im still waiting for some bigger pics of that beast the best coupe on this forum and universe
Posted on: 2014/4/15 9:48
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception not know by modern Australians http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
From Los Angeles,CA
Thanks D!
The front of the engine isn't leaking.. Back of the motor, and the front of the gearbox is..
Posted on: 2014/4/15 9:54
From Melbored
Darn sorry read it wrong!
pics of the body, tailights etc ;)
I hope that seal sleeve works for you, I cant remember but if you can quickly run through the specs of that motor eg. block, crank and bore size?
Posted on: 2014/4/15 9:59
(1) 2 3 »
