« 1 (2) 3 »
Re: Crankshaft Big End Diameter?
From Los Angeles,CA
A14 Block, A14 Crank cross drilled, knife edged, and nitrided.78mm Ross forged full floating pistons with titanium pins. Forged H-beam rods. Hollow Lifters, Aluminum roller tip rockers with solid spacers on thick walled shaft. Smith Bros tubular pushrods. Ported H89 head, 38mm Intake, 32mm exhaust, tapered bronze guides, 10,000 RPM double valve springs with titanium retainers. Chromoly Flywheel. All fasteners are either ARP or titanium...etc.
Posted on: 2014/4/15 10:29
yep best in the universe was right!
Posted on: 2014/4/15 10:32
From Los Angeles,CA
a few pics....
jpg  DSCF4869-lo.jpg (189.03 KB)
8618_534cfd58896c5.jpg 1000X1027 px
jpg  DSCF4861-lo.jpg (173.77 KB)
8618_534cfd9f3899c.jpg 1000X809 px
Posted on: 2014/4/15 10:41
Love the removable front cover made from another front cover for the timing case!
Is it stepped underneath or just using a sealant/ gasket etc.?
Also if you have a heater this can be done neater than I did but just wanted to
prove to myself it worked and looked cleaner than sitting on the inner guard.
The heater pipe return was cut and reversed so the heater line runs under the
exhaust and inlet hidden away from view.
Posted on: 2014/4/15 12:08
From Los Angeles,CA
That does look cleaner!. My Cam cover has a gasket. The hardest thing was making sure that the timing marks were in the right place. I don't have a heater and I got tired of that outlet pipe disitegrating, so I turned a new one out of 316 stainless....
jpg  A14Block_12-loRes.jpg (177.30 KB)
8618_534dd4df7be97.jpg 715X1000 px
jpg  HeatShield3_LoRes.jpg (187.50 KB)
8618_534dd4ebe4f97.jpg 547X733 px
Posted on: 2014/4/16 1:55
Very nice work
Posted on: 2014/4/16 7:37
absolute stunning!!
love hardcore a-series builds.
keep up the good work.
any videos of current setup?
cheers
Posted on: 2014/4/18 6:22
Did you out sealant under the main cap before torquing it down ? I had the same problem I thought the rear main seal was leaking with my fresh motor didn't realise they ran sealant under the cap
Posted on: 2014/4/18 23:34
datsun a15 ute
Speedholes on the engine mount love it, forgot Cal weather rids you heater needs, stainless water pipe YES!
Yep very necessary to dab a thin layer of sealant all round front and rear seals especially main cap, sure hes done that with that keen eye for detail? love the brass looking front crank pulley bolt!
Posted on: 2014/4/19 0:12
Apply sealant here
Posted on: 2014/4/19 0:53
« 1 (2) 3 »
