Weber troubles
Quite a regular
I've got an a14 with oval ports, I also have a downdraught oval port intake manfifold. I've got a 40mm sidedraught dcoe weber that I was planning to use but found out that know one makes single sidedraught manifolds... Weber have an adaptor for DGV to DCOE set ups, but it's round port. My question is can I use this? Will the I take me rough? And will it lose a heap of power? Please help. :(
Posted on: 2014/4/29 13:21
Re: Weber troubles
There is a single sidedraft Weber DCOE manifold available for both oval and round port A series engines.
Or are you trying to use a sidedraft DCOE as a downdraft carburetor?
Posted on: 2014/4/29 13:30
Re: Weber troubles
Quite a regular
Nah I wanted to continue using the sidedraught but ran into walls when I couldn't find single oval sidedraught manifolds.. Where have u seen them?
Posted on: 2014/4/29 13:39
Re: Weber troubles
I have seen them on eBay once in a while. Also on Facebook forums. Try contacting Redline or Stewart Wilkins Motorsport. There is also ReCarb Australia.
You are bound to find one oughta those three. Expect to pay $300 AUD plus though for a new manifold. The one you are after is a more uncommon type. But it exists, I am positive.
Twin carb manifolds are more common.
Posted on: 2014/4/29 13:43
Re: Weber troubles
Quite a regular
I'll have a look, but if not would that adaptor work? It will just be restricted to dgv size yeah?
Posted on: 2014/4/29 13:52
Re: Weber troubles
not sure of the adaptor do you have a picture?
Posted on: 2014/4/29 13:59
Re: Weber troubles
Quite a regular
I'll try and upload somehow
Posted on: 2014/4/29 14:15
Re: Weber troubles
Quite a regular
Posted on: 2014/4/29 14:18
Re: Weber troubles
From Townsville, Qld
Should email Rowland Manifolds (the topic of this link) and find out if he's actually making the single dcoe manifolds because the website doesn't seem to list pitcures
http://datsun1200.com/modules/newbb/v ... =ASC&type=&mode=0&start=0
Posted on: 2014/4/29 15:28
Re: Weber troubles
This is not for round-port
It bolts to a DGV (32/36) adapter.
Posted on: 2014/4/30 0:21
