« 1 ... 5 6 7 (8) 9 10 11 ... 19 »
Re: VIC - drag day - June 15th 2014
From Melbourne AUS
my cars ready. ill try not to break it before june 15
Posted on: 2014/4/29 12:39
1973 B110 A12
From Adelaide
I'm out unfortunately. I'll be out of the country with work.
Posted on: 2014/5/11 9:45
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Melbourne, Aus.
My cars back together and so far no leaks, Just need to get it tuned which may require the chokes you were going to borrow Mik. Not sure if we will be using the 38s or 40s but a dyno tune will sort that out. Also need to get the rear guards rolled a bit further to fit the new tires. Other than that good to go.
Posted on: 2014/5/12 4:47
From WA perth
it be good to be there an bring my car over an have run with you's
Posted on: 2014/5/12 6:51
I may or may not need them. Any one got a wide band 02 sensor setup I can stick in the tail pipe....
Posted on: 2014/5/12 10:16
From Melbourne AUS
what are you running for tyres ben? id like to run some 225 semi's on the rear if i can get some cheapies
Posted on: 2014/5/12 11:02
1973 B110 A12
205 I think ange. I need that fpr off you too lol
Posted on: 2014/5/12 11:36
I'll be running 205/55 semi's on mine for the day
Posted on: 2014/5/12 12:13
Car free
From Melbourne AUS
its here waiting for you mik
Posted on: 2014/5/12 12:49
1973 B110 A12
I have a set of silverstone 205/55/13 for the rear, I'm told their really soft and only good for drags or hill climbs. They are on a set of dragways and the offset puts them slightly closer to the guard than desired.
Posted on: 2014/5/12 13:12
