lifters question
From hamilton new zealand
can anyone tell me for sure if a12 lifters will go into a15s ? ive lost my a15 set, but have a spare complete a12 that i can strip, rang nissan and they said new a15 lifters were 35$ each, 280$ is too rich for my blood!
any helps greatly appreciated!
ben
Posted on: 2004/5/24 9:56
Re: lifters question
They are the same:
B110 A12 lifters:
13231-H1001 LIFTER-valve all B110
B310 A14, A15 lifters:
13231-H1001 LIFTER-valve all B310
BUT ... you shouldn't put used lifters on a different camshaft ... it will wear out soon ... If it is a late A12 (distributor under #3 cylinder), swap both cam and lifters into the A15, if the cam journals are the same size. Mark each lifter so you know exactly which lobe to match them to (don't mix them up).
Posted on: 2004/5/25 3:36
cheers, thatll save me a few dollars
Posted on: 2004/5/27 7:47
From sydney australia
you could also just get the lifters refaced,which is a simple machining job.that'll give the lifters
a longer life than if you put them in with the
matching cam.
Posted on: 2004/5/27 12:10
I tried to reface my lifters once on a valve refacer machine. This thing was set up to reface lifters with what i think was a 30" radius. Let me tell you, those lifrers were hard faced, & i do mean HARD.
I had to take only the very lightest of cuts & i was glad that they were near perfect anyway as it still took me near half a day. These were A10 lifters which have a part number of 13231-18001. This supercedes to 13231-H1000
If this number again supercedes to the one ddgonzal quoted, i would not be at all surprised.
Posted on: 2004/5/27 13:05
Love your Datsun.
Treat it well.
From Christchurch NZ
the last lot I had faced cost me $40 +gst.
the cam grind only cost $96! I was shocked.
Posted on: 2004/5/28 7:07
Forced Induction!
