« 1 (2)
Re: rear shocks for a coupe
From Melbourne, Aus.
Thanks for the input guys, I am leaning towards koni adjustable as there close to home readily available at the moment and will bolt straight in. Also have them in the front and am pretty happy with them.
Posted on: 2014/5/28 8:21
1200rallycar wrote:
hi-lux... in the rally car, just under $200
but have driven the rally car on the road a fair bit and it handles way better than my road car
Are they any particular model hilux or are they all the same part number/spec for all hiluxes? I'm assuming they are for the rear of the hilux, but thought I better check?
Posted on: 2014/6/1 13:35
John McKenzie
From Adelaide
Also interested to know about the hilux shocks if I ever need replace mine. At the current rate they'll probably fail from under use (rust bubble -> torn seal).
Posted on: 2014/6/1 17:56
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
I was going to use the hilux shocks in the stanza rear but we're about 40mm too short. They are air shocks from the front of a early 1990's hilux.
yes fronts. Look like this
got these bilsteins new and cheap though off ebay. Perfect in stanza
they are from diahatsu feroza.
Posted on: 2014/6/2 1:22
Hey Mik, I will take you up on your offer and give them a shot in the coupe and see how they fit.
Posted on: 2014/6/2 8:35
I can make them fit any hole.
Posted on: 2014/6/2 10:06
What you do by yourself is best kept to yourself.
Posted on: 2014/6/2 10:46
What!!!!! Thought we had your date weds night???
Posted on: 2014/6/2 12:12
From the middle of the top bush that squashes the bar body to half way through the bottom bolt hole
360mm extended
300mm compressed.
they are easy to compress hard to extend but I guess the diff and leaves pull the shock away from the chasis.
Posted on: 2014/6/2 12:17
« 1 (2)
