e85 what fuel ratio
From WA perth
I was just wondering what fuel ratio people were running in there cars on e85 an do you have numbers , as I,am getting my car turn next week on e85 pump fuel. I,am just open to peoples thoughts
Posted on: 2014/6/20 14:01
Re: e85 what fuel ratio
From Narellan,Sydney
Fuel ratio? As in premix ratio?
Posted on: 2014/6/20 14:25
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From WA perth
AFR
Posted on: 2014/6/20 14:37
85% ethanol, 15% petrol
Posted on: 2014/6/20 20:52
From Albury
Good question. You beat me to it.
Also plugs need to be hotter and more timing ???
Posted on: 2014/6/21 0:25
From Sydney
Just looking over some of my dyno data.
On twin weber carbs we got the AFR between 11.3 to 12.9:1 across the RPM range.
cheers
benny
Posted on: 2014/6/21 0:31
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
The AFR meter will read the gasoline AFR if its read by a wideband sensor.
Actual AFR of 12:1 is extremely lean for E85.
Posted on: 2014/6/21 3:57
wideband O2 sensor
A reading of 1.0 lambda is stoich for petrol
A reading of 1.0 lambda is stoich for E85
The output of a gauge or a dyno will be for petrol unless it is switched.
Stoich is 14.7 AFR for petrol but 9.8 for E85
For maximum power is should be much much richer
Posted on: 2014/6/21 4:02
From WA perth
right boys ,you all seam to be all over the shop . I didn't mention I have a15 turbo motor on boost an i'am running a AFT at the moment at 11.5 an I thought I ask what other boys are running if you can run it leaner.
Posted on: 2014/6/21 6:01
