Ca18det oem valve lifters
From Goulburn NSW
Hi guys just would like to know whether or not the oem lifters will cope with 3-400hp?can only get oem.
Posted on: 2014/6/29 7:29
Re: Ca18det oem valve lifters
From Canberra
Mine is smack in the middle. No problems with oem lifters. Solid if you want high rpm and high valve lift.
Posted on: 2014/6/29 14:17
From Goulburn NSW
Hi guys what is the difference between hydrolic and shim lifters?tried googling it and couldn't get a definitive answer.
Posted on: 2014/7/22 9:54
From Mudgee NSW Australia
The eom hydraulic lifters are fine I use them in my CA18 thats spinning to 8500 and making 340rwkw no issues as yet. The solids are for higher lift cams are a bit of a pain to setup. That's why I stuck with the hydraulic ones.
Posted on: 2014/7/22 11:00
If In doubt run more BOOST
From Goulburn NSW
Does anyone know whether or not any other Nissan(sr,rb etc etc) valve retainers will work with the ca18det?
Posted on: 2014/7/23 5:01
