itb size for worked a series?
From mandurah
just wondering what size throttle bodies would be best suited to an a15 with alot of work?
engine specs
12:1 comp
port work and 5 angle valve job
extractors
wolf 3d ecu and indivdual coils
balanced and a few other bits
i have a set of 36mm itbs ,and my old carb setup had 34mm chokes ,so does thast mean the itbs will flow more than the 34mm choked carbs? and the itbs dont have an inner venturi like carbs
also my runners are 38mm od and taper into the oval gx port
dont really want to make the manifold up then find the setup i have is too restrictive and will need to be changed
aiming at 130rwhp
cheers
Posted on: 2014/7/3 4:54
Re: itb size for worked a series?
Yes, 35 bores will flow more air than 34 mm bores. A15 ports are 28x34.
Posted on: 2014/7/3 6:13
From mandurah
head has been matched to gx ports :)
ok sweet well the 36mm itbs should be about right then
now to finish the mani and do abit of wiring to make it all run!
Posted on: 2014/7/3 6:54
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Adelaide, Australia
Doesnt itb size get determined by revs and cc's? Or is that just carbys because of velocity? Sorry just learning about all this
Posted on: 2014/7/3 8:13
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From Perth
If you ever want to step up I have some 50mm :)
Posted on: 2014/7/3 14:32
You can get 55s from TWM
But pipes larger than the ports will only slow it down.
Posted on: 2014/7/3 21:55
Going from what Steve Newing ran on his race 1200 coupe with 1580cc A15, you should go for Neils 50mm units as the A15 rod stroke ratio, revvs and double the capacity of a bike engine would mean 48-50s would be right on for 1.6L with that high comp and short TDC event especially when using fuels like e85.
Posted on: 2014/7/4 12:37
From mandurah
Yea I hear what your saying but if the port is smaller than what the throat of the throttle body is then its not going to flow any more
Being said, bigger means less restriced intake and unlike carbs I dont need to worry bout low down air speed
Interested to see it running, had A play with the ecu and I have got it to fire inkectors and stuff so need some coils and to finish the mani and I can try start it!
Posted on: 2014/7/4 19:41
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
tapered manifold will make a difference, sounds like a ripper motor!
Posted on: 2014/7/5 9:17
From South Africa
Don't suppose you'd know the brand of those itb's? Sounds like a heap of fun
Posted on: 2014/7/5 9:27
