mig or tig..... turbo manifold under constructin
Quite a regular
From JUNEE NSW AUSTRALIA
hi people building a turbo manifold for an A1400
I can mig and stick weld .
but what is the best for home made manifold using buttweld angles and steam pipe tig or mig I can pay for someone here to tig weld if I have to ....... but if mig is ok I will do it myself which is the best thanks.
moridat .
Posted on: 2014/7/14 11:29
OLD DOGS CAN LEARN NEW TRICKS
Re: mig or tig..... turbo manifold under constructin
From Narellan,Sydney
Mig is ok and quicker but tig is preferred looks much nicer and stronger.up to you really
Posted on: 2014/7/14 11:44
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Quite a regular
thanks for the advice it it advisable to grind back and clean up the welds
thanks for the help
Posted on: 2014/7/17 2:50
From Melbourne,Australia
I tacked mine together with a mig then had it professionally tig welded.
Posted on: 2014/7/17 4:41
The contents of the manifold wont mind wether it is Tig, mig or arc.
Do whatever suits you best.
Posted on: 2014/7/17 8:24
From Sydney
Go1200 migged mine and it's been perfect but as everyone has already said, Tig is best if you can afford it. The main thing to remember is the quality of weld on the inside of the manifold. Get in there with what ever u can and make sure there no slag waiting to come free and wreck your turbo. Good luck and post up some photos.
Posted on: 2014/7/17 8:45
Quite a regular
thanks for the input I think that I will mig it I worked as a welder for years the only trouble I have now is that I need a reasonable light source I will give it a go and see what happens I can only stuff it up.. then I will start again if it works I will post some pic,s we will see what happens.........???????????
thanks...moridat
Posted on: 2014/7/17 11:07
