Browsing this Thread:
1 Anonymous Users
Bad vibration A15 when reved |
From brissie
The sunny has a bad engine vibration that's getting worse. Don't run a tacho so don't know revs but it start at 85kph and goes away at 95kph can feel it real bad through accelerator pedel ( what ever that rev range would be). Now I know the box is on it's way out as the bearing is fukd. When it started to do it I could hold revs and push clutch in and it would go away. But now it's there with clutch in and free rev motor. Have disconnected fan belt as I thought may have been fan or water pump as fan is clutch fan but still done it. As said I don't know the rev range but at a guess maybe 2500-3300rpm. If I free rev it the vibration only is there really bad in that rev range that it comes back through the accelerator pedel and it's almost too bad to keep your foot on it at that rev range. Changing box today but thought while it's out change spiggot also. ??????
Posted on: 2014/7/27 3:05
Re: Bad vibration A15 when reved |
From brissie
Ok just removed the box and started the motor and the vibration is still there. This do t sound good
Posted on: 2014/7/27 4:12
A12,4spd, mild cam ,head work, mags.
From Kelmscott Western Australia
Why dont you try looking at your e/mounts and exhaust see if its hitting anywere
Posted on: 2014/7/27 4:45
71 Datsun 1200 ute with A14 fuel injection and T50 59 Morris minor ute with A15 fuel injected with intercooled turbo
From brissie
Good point exhaust not hitting and mounts still new. Just dropped the oil and there is shiny bits. Hmmmm.
Posted on: 2014/7/27 6:04
Not too shy to talk
From Mauritius
does the vibration stop if you rev higher?
Posted on: 2014/7/27 18:54
Not too shy to talk
From Mauritius
could be a leak in the intake manifold somewhere affecting compression. i had this issue last time when cracked my manifold while mounting it. it would run very rough upto 3000 rpm but run ok above.
Posted on: 2014/7/27 19:00
From brissie
Yes it does. But it only vibrates at the rev range. So smooth as below say 2500 then it vibrates real bad to about 3000-3500 then stops
Posted on: 2014/7/28 8:46
From New Zealand
Bulge in a tyre shows up in roughly that speed range
Posted on: 2014/7/28 9:42
From Adelaide, SA
Or uni joint in the tail shaft?
Posted on: 2014/7/29 0:28
Not too shy to talk
From Newcastle
Check the little metal straps that hold the pressure plate to the clutch housing. Pull an L20 apart one weekend looking for some vibration. Turns out it was these things bent when I missed a gear when racing.
Posted on: 2014/7/29 2:38
