E85 and fuel lines?
From Melbourne, Aus.
Do you need a special type of fuel line to run E85 or are the fuel lines at the local repco etc suitable?
I have read that modern fuel line is fine and also read that it isn't, anyone know what the answer is.
Posted on: 2014/8/26 10:10
Re: E85 and fuel lines?
From Sydney , NSW
Repco or similar will have what you want. It will be printed with E85 or ethanol compatible.
Cheers.
Posted on: 2014/8/26 10:50
All torque, no traction
A division of "My mate's ....." engineering
Bio line I have I got from Repco and is good for e85 I believe also areo flow do e85 braid
Posted on: 2014/8/26 11:12
Car free
Cool thanks. Will start by getting that tomorrow, I will also need a product to seal the threads at the pump, would anyone have any suggestion of what i can use, i dont really trust the people at the shops around here.
Posted on: 2014/8/26 11:28
From Adelaide
ptfe tape (aka plumbing tape) is fine if you're careful to keep it to the thread that mates. There's a loctight that does the job (we have it at work but I can't remember the number). A thin film of gasket silicone will also work as will a decent epoxy. (I've successfully used all 3 sealants.)
If you use the silicone or epoxy give it 24+ hours to cure properly before pumping fuel through.
Personally I wouldn't worry too much about the fuel line, just keep an eye on it. If it's not compatible with ethanol it'll either swell and soften or shrink and go hard, neither are likely to fail straight away if the hose is in good shape.
Posted on: 2014/8/26 12:15
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Melbourne,Australia
I have used proflow E85 compatible hose and fittings when I did my fuel system.Also the hard lines are alloy but coated internally to be E85 resistant most important thing you need is good fuel filters e85 will strip whatever rust or loose stuff is in you fuel tank and lines and block things up very quickly. Also don't use paper element filters as they swell Ive again used the proflow ones that have removable stainless filters inside that you can clean.
Posted on: 2014/8/26 22:59
From Narellan,Sydney
You don't need any tape for fittings.they seal them selves.you just need a copper wash for tge pumps.best to use teflon lines and stainless filters
Posted on: 2014/8/27 7:46
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Thanks, thats what i need to know.
Posted on: 2014/8/27 21:50
