« 1 ... 7 8 9 (10) 11 12 13 »
Re: Nicks datsun 1200 ute
From Kelmscott Western Australia
Update
New engine
5 speed box
And half way through putting in Air con just need a reciver dryer hoses and gas
jpg  20141013_174622.jpg (115.19 KB)
13822_543ba7a1bcd4f.jpg 392X294 px
jpg  20141013_174638.jpg (110.05 KB)
13822_543ba7b1b39af.jpg 392X294 px
jpg  20141013_172938.jpg (108.59 KB)
13822_543ba7c0463c8.jpg 392X294 px
jpg  20141013_174749.jpg (106.38 KB)
13822_543ba7d1bba01.jpg 392X294 px
jpg  20141013_174703.jpg (99.13 KB)
13822_543ba7de27cf3.jpg 392X294 px
Posted on: 2014/10/13 11:22
Just recently fitted intermittent wipers
Got the bits out of a gb122 sunny truck
Want it to rain now so i can use them
jpg  20141230_172253.jpg (68.16 KB)
13822_54ba13f83dbf3.jpg 313X235 px
Posted on: 2015/1/17 7:50
From Mordialloc Victoria 3195
I did a similar notch out on the gearbox mount, then welded in a reinforcing plate plate with a 35 hole in it so I could keep the reverse switch. Only thing is I had to make a cover pate with a small hump to fit over it, hardly noticeable under the carpet.
looking good - yeah you need air con in WA
Posted on: 2015/1/17 19:28
keep it simple
Update
Recently i pick up a dogleg 5 speed so i decided to fit it and test in the ute and i got my std shift 5 speed rebuilt with bearings and sychros now its nice quiet and smooth
jpg  IMG_0123.jpg (118.77 KB)
13822_54e5bdb9389d2.jpg 392X294 px
jpg  IMG_0124.jpg (129.30 KB)
13822_54e5bdc94f1e7.jpg 392X294 px
jpg  IMG_0128.jpg (98.76 KB)
13822_54e5bdd6ba271.jpg 392X294 px
Posted on: 2015/2/19 10:41
From Freo
nice work on the ute Nick
Posted on: 2015/2/19 22:07
A15 PSI Project Motor
'72 CB750k,
Cheers dundee keeps me out of trouble
Posted on: 2015/2/20 4:42
New update
Fresh up on the e15 dizzy as the mechanical advance was stuck
Air con all hooked up cold on the lowest setting
And picked up a h150 3.8 ratio new old stock crown and pinon set so it might end up in the ute for more legs down the highway
Posted on: 2015/5/9 10:53
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Mmm, aircon sounds nice.
3.8, isn't that what most H145s come with? I see your ute came with H145 for some reason, then you swapped an H150 into it. H150 4.11 gears is quite rare, most are 3.889 or 3.7.
very nice
Posted on: 2015/5/9 11:06
Got a 4.1 h150 now
Thought in the past to put the h165 in but not worth it to high rev even with a 5 speed
Revs at 3k on the highway in 5th
Be lower when i put the other one in nice and cruize
Posted on: 2015/5/9 11:37
From MOOROODUC. Victoria
My CA18 cruises at 2600 rpm at 100K's with the Ute diff (I think it's 4.1). ...
nice build
Posted on: 2015/5/9 13:23
