Hi all,
I'm new to this forum, but my topic isn't. I'm the new owner of the GrimReaper jet boat that's been discussed here before (
http://datsun1200.com/modules/newbb/v ... 43&forum=1&post_id=133738,
http://datsun1200.com/modules/mediawiki/index.php?title=Boats). And I still have the same issue - I need more power.
It's a tiny 2.9 meter jet boat that weighs maybe 500kg and is powered by an A12, which has just been re-built by the previous owner, but without any mods. With one person it goes fine, and under full throttle gets on the plane in a fairly short time. Once on the plane it goes pretty fast - speedo not working atm so not sure how fast, but quick enough to run around citycats. With 2 adults it can't quite get on the plane and so is painfully slow - tinnies passing us.
I talked to the mechanic who did the engine rebuild, and he seems to know what he's doing, and he suggested going turbo. One of the challenges is that the manifold is a DOEN marine manifold which also circulates the river water to cool the engine. Also, unless you pull the motor, you cant dyno a boat (easily). The proposal is to put on a Garrett T20 in a draw-through configuration to get to about 10psi boost, which he said the unmodded engine should be able to handle. BTW it has a 2 barrel weber, which he'll re-use.
It's all going to cost of few $$$ because I'm having him do all the work and there is a bit of fabrication involved due to the marine manifold and exhaust. So, question is, how much power boost could I expect with this? Any other ideas or things I should consider?
thanks
