« 1 ... 47 48 49 (50) 51 52 53 54 »
Re: Leveys 2dr sedan v1.2
From Perth WA AUS
I picked up a ute diff yesterday, donated by a kind member of this site :)
Dont know when i will fit it but it wont be soon.
Posted on: 2014/11/24 9:18
Datsun 1200 2Dr sedan.
Bargain from Mr. Verban as usual, great purchase Levs.
Not many tudor 12s in Oz but your beast is definitely the best in Oz.
Posted on: 2014/11/25 1:21
From Perth WA AUS
Thanks D, Its getting there finally.
If I stopped changing things it would be finished but at least its a goer.
Posted on: 2014/11/25 7:26
From Snohomish, WA USA
Hey levey,
What brand of clutch and what's the specs. on it?
Posted on: 2014/11/27 5:36
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Perth WA AUS
Hi Ernie,
the clutch is a Tilton 7.25" single plate.
The code on the box is hard to read but looks like 66-001HORA.
Does not fit standard flywheel unless you machine & modify the flywheel.
Hope this helps, its not in the car yet.
Cheers, Levey.
Posted on: 2014/11/27 6:13
Just wondering. That solid disk looks stout. I dropped the stick an am going automatic.
Posted on: 2014/11/27 20:01
'73 2 Door Sedan
Nige like to grip on tightly to anyone's stick
Posted on: 2014/11/27 20:52
like earlier stated Levs, best use the solid clutche as a template to make a 6 puck sprung centre combo from scratch or use something off the shelf and just change the spline like the VW Polo which is the one I was going to use. The D series honda sample below is an image to help in terms of design but using VW POLO 175mm one, just gotta find out which one as they have 175 and 190mm and maybe others. Thats all I can remember now but will be very useful & more common than aftermarket A series ones!
eg.
http://www.amazon.com/Yonaka-Series-S ... words=clutch+plate+6+puck
Polo sizes
http://www.tigerstyle.co.uk/phpBB3/vi ... .php?f=19&t=57588#p452359
maybe this one
http://www.vwsonline.co.uk/car_parts_ ... h-kits/028-198-141dx.html
Posted on: 2014/11/28 0:26
Edited by D on 2014/11/28 1:12:30
Edited by D on 2014/11/28 1:12:56
From Perth WA AUS
Thanks D,
I have been told the plate is still serviceable but any probs and I'll get a new one. the are only about $110.
I know it will be a bitch to drive on the street but there is no room for an organic plate with this setup as the flywheel is matched to the clutch set up, custom clutch would be big $$$.
I like this setup :)
Posted on: 2014/11/28 7:15
longer support stems and bolts can be sourced from Tilton
modded polo td clutch plate inc. plate should cost no more than 150
Posted on: 2014/11/28 11:00
