« 1 ... 48 49 50 (51) 52 53 54 »
Re: Leveys 2dr sedan v1.2
From Perth WA AUS
Your a legend D,
I did not even think about longer support stems and no body I went to did either, damn experts!
I will look into this further, thanks for the info.
Might be a streetable car afterall :)
Posted on: 2014/11/28 11:07
Datsun 1200 2Dr sedan.
Nah just a car nerd as was heading that way before I went to the CA20DE.
You can get longer unbreakos from a bolt joint but the stem supports have
to be from Tilton or use modded spacers
Posted on: 2014/12/1 11:21
From Perth WA AUS
Thanks D :)
Posted on: 2014/12/1 12:46
From Canberra
What alloy radiator are you using?
Posted on: 2014/12/3 9:47
From Perth WA AUS
Its an ebay item, got it from a mate though.
I think he paid about $300 but now they are alot cheaper.
Works well too.
Posted on: 2014/12/4 9:53
From Perth WA AUS
260z Alloy rear drums to go on the h165 diff.
Ex race brakes so the set up has lots of holes drilled into it, most you cant see in the pic.
jpg  IMG_20141220_155708.jpg (168.62 KB)
9665_54952f091436e.jpg 908X681 px
Posted on: 2014/12/20 8:10
Great score Levs, Ive seen them with even more holes on the drum
and also on the shoes main bridge, but crazy what Z freaks do when
the L6 is such a heavy block! We are blessed with litte A series.
To think this option for Corolla Ke25 (aka TE27 special TRD items)
will set Toyota peeps 950 USD but we get them cheap from the Z.
Posted on: 2014/12/20 13:52
From Perth WA AUS
Yeah, only problem is the backing plate bolt spacing is too big.
Maybe I got the wrong year/model? Have to see if I can mod them maybe, or find some bluebird backing plates.
Posted on: 2014/12/20 22:20
I think you do have to get the bluey s2 backing plates
The drums are bigger to accomodate for the heavier
bluey car weight compared to the 1200 ute.
Posted on: 2014/12/21 0:35
From Perth WA AUS
Yep no way I can mod these, what year bluebird though?
Posted on: 2014/12/21 1:55
