Browsing this Thread:
1 Anonymous Users
engine build |
Quite a regular
From Adelaide
I'm thinking oval port A14 with S14 charger, custom cam, flat top pistons, 5 speed box, R31 diff and suspension with 15 inch rims.
Any issues with combinations or anything like that?
Posted on: 2014/12/30 5:52
Re: engine build |
Registered Users Contentmaster Usermaster
Skip the flattop pistons. You can make more power with the stock dished pistons when turbocharged.
The S14 turbo is a little small. Sikyne used an S15 type turbo (T28) and made 160 HP with a stock A12 engine fitted with a stock A14 cylinder head.
Posted on: 2014/12/30 6:21
Re: engine build |
From melbourne
Would you need a R31 diff ?? Wouldnt a H165 be enough ??
Posted on: 2014/12/30 7:20
Re: engine build |
Go the H165 first. If blow up. Change.
Posted on: 2014/12/30 8:05
Re: engine build |
Quite a regular
From Adelaide
Oh right so there's no advantage of flat top pistons? I've also heard using a single turbo off of a twin turbo works well? Might look into the T28s
Only reason I was thinking the 31 diff was to save the hassle of having to do things over again and then I don't have to worry too much about it in the long run
Any advantage of turbo over supercharger? Which would be better for daily driving?
Posted on: 2014/12/30 9:32
Re: engine build |
From melbourne
Mmm Chicken or the Egg ?? Either if your looking for cheap A14 build and aiming for 100HP or so and streetable. I would leave the entire motor stock, even the head, except for good rod and head bolts (maybe o-ring it) with around 8.5cr, 8psi boost and a cam re-grind, good up to 7K mark. If your aiming for 130HP+ it will be more achievable with the turbo. And of coarse it will cost more money... T28,(personally), way too big for a daily driver street car, max t25... There are plenty of articles in details( caged or free range) on this subject, just look in Search. Good luck
Posted on: 2014/12/30 13:52
Re: engine build |
Quite a regular
From Adelaide
I've taken my ideas to an engine rebuilder that has quite a bit of experience with Datsun engines and he's working on the rough cost of the rebuild.
He's even offered to quote up an SR20 conversion for free to compare the two and see the power/ cost difference Only problem with SR is getting engineered whereas with A series can get away with it if I ever got pulled over and checked
Posted on: 2015/1/1 8:19
Re: engine build |
Cops are switched to the smallest of mods these days so engineering is a must for over 120hp ate.
The only way to get away with it is to use a a12 block with A14 crank, a12 rods and milled A15 pistons for a 1400cc hidden in the A12 block, rowland downdraft mani with 32/36 or 36/36 ida/f on a stock looking filter housing or similar, some excellent headers/zorst, cam and the rest. This done right will net you 100hp at the engine at best.
120hp requires very high compression, capacity with awesome planning, tuning, many hours! A series guru style porting work that will cost more than an a stock NA ca or sr in the end. If you have a builder that knows his stuff he can do a full sleeved, cemented A12 with 4age early 17.5 pin pistons same A12 rods, A14 crank, cam & rest as mentioned for 1587cc, 10.5 comp possibly 100hp atw at 7500rpm is within reach. PJZ can supply 80mm head gaskets to use.
Only a few A series tuners can achieve this and the sleeve, grouted 4age piston route with carefully flowed head and rest would be the only way to get stock NA SR20DE power in an A series that looks reasonably stock bar the headers but all within a little A12.
This is not unreasonable but dont expect beyond 100hp atw from an NA A series that looks stock.
Posted on: 2015/1/2 4:10
Re: engine build |
From melbourne
Is a engineers required for A14 ??
Posted on: 2015/1/2 6:38
Re: engine build |
It's borderline but technically as it wasn't offered as an option in the b 110 b210 chassis in aus it needs sign off. Even b 310 sedan nerds It although wagon does not. Stupid adrs
Posted on: 2015/1/2 6:41
