« 1 ... 4 5 6 (7) 8 9 »
Re: Ca18det 1200 ute.
From Goulburn NSW
Hey mate what thickness head gasket did u use,did u shave the head?
Posted on: 2014/10/20 5:51
From Mudgee NSW Australia
Hi mate sorry it took me so long to answer its running a 1.3mm MLS headgasket the head was surfaced but not much taken off just a clean up.
I'm in the process of doing more work on her with the power it was making has broken quiet a bit. Upgraded to 31 spline billet axles after twisting the 28 spline ones. Running a Jim Berry single plate with heaps of clamp after cooking the OSG. Broken the RB25 gearbox installing ppg billet selectors and a few other goodies to help it shift better and more reliable. Also fitting a larger 5558 turbo and a retune should see close to 400kw
jpg  10675581_844011355620652_3990594695738182401_n.jpg (50.66 KB)
33_54a60eb315301.jpg 800X533 px
jpg  10850083_845247922163662_2546995915717477249_n.jpg (56.24 KB)
33_54a60ed09ce8a.jpg 800X533 px
Posted on: 2015/1/2 3:21
If In doubt run more BOOST
A picture of the engine bay these days. Pretty happy with it
jpg  rsz_1rsz_ca18_moterfest.jpg (91.71 KB)
33_54a6116f84840.jpg 768X512 px
Posted on: 2015/1/2 3:33
From Melbourne AUS
Looks great I can't begin to imagine what that sorta power feels like in a 1200 ute!
How does she go on the circuits?
Posted on: 2015/1/2 3:48
1973 B110 A12
It actually handles quiet well lots of fun still sorting it a little.
I don't run high boost on circuit as it just bakes the tyres.
Hooks up nicely with with the spool and caltacs. Stops really well now I have some project Mu pads
This year money permitting will be doing a lot more events.
Im aiming for a 1.06 around Wakefield Park and a 10 flat quarter mile
last year saw a 10.8@133 and a 1.10 around Wakefield with brake and traction issues.
Posted on: 2015/1/2 4:24
Pack lots of brown undies in the tray too. Nice build
Posted on: 2015/1/2 4:27
From Goulburn NSW
Hi Andrew,i have a question for u.Im planning on running tomei 270 cams like u and would like to know did u have to machine alot out off the head to get them to work.
Posted on: 2015/2/5 6:05
From Canberra
Andrew,
How do you find the Caltrac on the circuit? in comparison to your old coupe do you think they are a worthwhile upgrade or do they bind under curtain conditions on the track?
Bryan
Posted on: 2015/2/6 9:01
Mcdat I had to recess the head a little for cam lobe clearance around 1mm or so not heaps and also running tomei springs.
Mcgee It handles different to the coupe not in a bad way its a lot more aggressive with how power comes on . Doesn't squat as much as the coupe did but still feels predictable. Next track day I do i plan on doing some laps with them disconnected just to see if it does make a difference. It doesn't bind up and still turns in pretty well. I'm looking forward to more track time once my gearbox is repaired.
Posted on: 2015/2/9 2:46
From W.A.
Hi Andrew. Your ute is looking great and not as dusty as your old coupe is in my shed. Kids seam to take a toll on motorsport. I would love to know more about the adjustable cams, are the the same as the coupe. I am able to get around 250hp @16 psi but can't get near your old 300hp+ figues. do you remember if you played with cams.
Like I have said before the coupe turns heads and I know I will kick myself if ever I sell it it is over 40 years old now and aging better than me.
Jeff
Posted on: 2015/3/31 13:14
