« 1 2 (3) 4 »
Re: Dime Quarterly 200sx efi conversion article?
Vacuum hose ports: plug with a rubber cap. Or cut the hose and insert a stick of appropriate diameter. Or a bolt. Or a golf tee.
Exhaust port (small tube): Unscrew tube and plug with a threaded fitting. Some guys cut, pinch and weld the tube.
The EGR Valve itself leaves a hole if removed. A small aluminum plate is easy to fabricate. If you remove the entire EGA adapter, it leaves a big hole, and as it is underside, not reason to remove it.
Posted on: 2015/1/20 3:42
From Sydney, NSW
Thanks David
Most appreciated.
I'll set up a build thread once I see if I can get the ecu sorted
Posted on: 2015/1/20 3:46
EGR - I would leave the adapter (EGR Passage casting) on the bottom of the manifold.
See GX-E section "EGR"
Posted on: 2015/1/20 4:05
From Sydney, NSW
I'll take some photos once the manifold arrives and then start blanking things off
Thanks for all your help with this
Posted on: 2015/1/20 4:07
From Sydney, NSW
Is the tps on the stock manifold a full function tps? If I had to go aftermarket ecu I think it would be needed.. Some of the earlier ones were more on off switches
Posted on: 2015/1/20 8:23
I don't know. You can check the function in the 280Z Service Manual.
If you go MegaSquirt ECU, it can use either type, or no TPS at all.
Posted on: 2015/1/20 8:41
From melbourne
What about loom?? What would you expect to pay to get it all wired up??
Posted on: 2015/1/20 8:51
If you get the Datsun parts, get the loom too. Only 7 wires need to be connected externally, the loom takes care of the rest.
This is definitely a DIY project.
Posted on: 2015/1/20 9:45
From stinking hot cairns
You can use no tps BUT you wont be able to use flud clear mode witch can be a pain in the arse.
Posted on: 2015/1/20 9:57
flud clear mode?
Posted on: 2015/1/20 10:09
« 1 2 (3) 4 »
