« 1 (2) 3 4 »
Re: EGI What are these things on the manifold and which ones are needed?
Why replace the throttle body? It comes with a two-stage one, good for top-end power and also good for low-speed power. And will make 92 horsepower.
Posted on: 2015/1/29 11:04
From Sydney, NSW
Good point!
I will replace the tps with a modern style one though
Posted on: 2015/1/29 11:11
The Datsun TPS can already tell if you hold the throttle to the floor (it has full-throttle detection). The stock ECU has no problem with flooding, but if you go to an aftermarket ECU you might want to change to a generic type of TPS.
Posted on: 2015/1/29 21:25
From Sydney, NSW
Thanks DD I'm thinking aftermarket. I found a stock a15 ecu but no loom. I suppose I could make one as the connectors are quite large but just tossing up between the two :)
Posted on: 2015/1/29 21:43
From Sydney, NSW
hi! Just wondering with this photo http://datsun1200.com/modules/myalbum/photo.php?lid=21839 if I'm not connecting the EGR stuff will sensors A and B still function or will I need to relocate them to somewhere else?
Thanks,
Tom
Posted on: 2015/7/3 22:19
To disable the EGR, just plug the little vacuum hose. For a cleaner look you can remove the valve and create a blocking plate, also remove the EGR Tube and block the hole.
A is for EGR
B is for the ECU (water temp sensor), you will have to relocate it should you remove the EGR Passage.
Posted on: 2015/7/3 23:08
On the pcv port, is this full manifold vacuum? Looks like it may be, but it shouldnt. Carby pcv goes to the air cleaner, so a slight vacuum.
Posted on: 2015/7/4 7:09
You might be thinking of something else. PCV is connected to full manifold vacuum.
Here the PCV is screwed into the manifold plenum on a standard A12
On the EGI engine, it screws into the rear of the manifold plenum
Posted on: 2015/7/4 7:35
From Sydney, NSW
For egi would you just run a rubber hose?
Posted on: 2015/7/4 7:45
For EGR, if that's what you meant, I would leave it connected and working. Less work that way. If you wish to disable it, simply pull the small hose off the valve and put a plug in the hose.
I like to keep it simple in order to get the engine up and running as quickly.
Posted on: 2015/7/4 9:14
« 1 (2) 3 4 »
