« 1 ... 61 62 63 (64) 65 66 67 ... 97 »
Re: Super Bee KA24DR Mod
Nice pulley
I used that drink too
Posted on: 2015/2/9 4:57
From Snohomish, WA USA
Another photo of the supercharger crank pulley.
Today another task completed. Wrapped transmission tunnel with fire hose for a make shift scatter shield. The stuff is very durable. I used sprayed adhesive to put it down but will add bolts and fender washers in key areas. Kind of looks like a broken bone cast. Painted it in a good thick coat of flat black. I think it turned out good.
Might finish up the wiring and put the gauge cluster in tonight.
Progress.
jpg  IMG_20150208_142921_011.jpg (123.72 KB)
39_54d97d49bfd96.jpg 459X816 px
jpg  temp.jpg (137.43 KB)
39_54d97d5cd88c2.jpg 459X816 px
jpg  temp_3.jpg (140.52 KB)
39_54d97d79177a9.jpg 816X459 px
jpg  temp_2.jpg (156.74 KB)
39_54d97d8edf3ae.jpg 816X459 px
Posted on: 2015/2/10 3:43
Edited by datsa73 on 2015/3/6 16:51:55
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
A lot of items on the table to complete.
1. Install new gauge cluster
2. Install transbrake in Powerglide transmission
3. Finish up electrical wiring
4. Brake lines
5. Install motor and transmission
6. Exhaust pipe reroute around transmission
And a few other items.
Continuing the project.
Yesterday I finished up the header. I decided instead of having a larger breather on the valve cover to vent the crank case of pressure, I went with modifying the header and adding a one way breather valve. I think this will be more effective.
I have some kitchen cabinets to build so Im taking a break today.
jpg  IMG_20150217_153031_901.jpg (131.20 KB)
39_54e4d4184e12b.jpg 816X459 px
jpg  IMG_20150217_173115_093.jpg (108.81 KB)
39_54e4d42b35480.jpg 459X816 px
Posted on: 2015/2/18 18:04
'73 2 Door Sedan
Built this blow off valve yesterday. I had had back fire problems when I was testing jets on the carbs. I've had the output port of the SC blow the 1/2 inch aluminum plate twice and warp it. This should solve the problem.
Wasn't on the list of stuff to do but needed to get done.
Going to try and mount the Hurst shifter today. Need to do that before the tranny goes in.
jpg  IMG_20150221_181633_362-1-1-1.jpg (177.72 KB)
39_54ea01a91fc58.jpg 835X1140 px
Posted on: 2015/2/22 16:35
'73 2 Door Sedan
Nice
Posted on: 2015/2/22 17:58
Finally put the new gauge cluster in. Very busy but turned out good.
Well the back seat is now out for good. No one has sat back there since my kids were little. Its almost now impossible to get back there with the roll bar. So its out. Took out 25 pounds of Seats and belts and put in 2 pounds of aluminum sheet. The trade off was worth it.
Next is working on the Transmission and putting the engine back in. I'm close.
jpg  IMG_20150302_135122_826.jpg (171.89 KB)
39_54f52b7c54ddc.jpg 816X459 px
jpg  IMG_20150302_182041_252.jpg (135.54 KB)
39_54f52b8ae8285.jpg 459X816 px
jpg  IMG_20150302_170731_303.jpg (107.84 KB)
39_54f52b9fb0188.jpg 816X459 px
Posted on: 2015/3/3 3:34
'73 2 Door Sedan
Thats dash! Id pay you for the template if I had a 1200, looks racer 60s erotica
Posted on: 2015/3/3 4:49
Thanks! I have a second dash with less holes that I did not use.
Hopefully the motor and tranny back in this week.
Posted on: 2015/3/4 15:23
'73 2 Door Sedan
Worked on the transmission and trans brake yesterday. Took it over to a friends shop with a parts washer. I gave up mine when I moved to a smaller garage.
The TCI trans brake valve body had a broken spring so I had to order it.
Dead in the water now with work so decided to install some Amber LED ground effects lights on the bottom of the car and in the wheel wells. Feel like I'm 16 again.
Posted on: 2015/3/6 16:40
'73 2 Door Sedan
Transmission complete and engine and tranny back in car.
I started my fuel cell project so not finished.
Gas tank and fuel lines are out so the car is going no where.
Probably another couple of weeks with shuffling house work stuff.
jpg  IMG_20150317_153808_323.jpg (166.89 KB)
39_550dc8ab1857d.jpg 816X459 px
jpg  IMG_20150317_205611_701.jpg (149.25 KB)
39_550dc8b72fb2b.jpg 816X459 px
Posted on: 2015/3/21 19:40
'73 2 Door Sedan
