(1) 2 3 4 ... 48 »
Turbo EFI A12 for under $1200. Discussion thread
From Ballarat Victoria
For a long time ive wanted to put together a simple Turbo A12 setup that retains the use of all the standard running gear and keeps an almost standard appearance. I'd like to keep it very simple using as many standard parts as I can to make it easier for people to copy.
It will be fuel injected with ignition control as well.
Power will probably be in the range of 50 to 70 Kw atw(Stock A12 is 20-25KW). I think it is important to keep these figures reasonable to be able to use the standard gearbox as beefing up gearboxes is $$ and not easy to do.
I'll do a step by step and a parts list for anyone wanting to follow along. Be prepared for a few bumps and laughs along the way(probably mostly from/at my ideas)!
Stay tuned for Part 1 next week... The EFI manifold.
The build thread: http://datsun1200.com/modules/newbb/v ... e=&topic_id=64661&forum=9
Posted on: 2015/3/11 6:07
Edited by sikyne on 2015/3/17 4:00:55
Edited by sikyne on 2015/3/17 8:58:14
Edited by sikyne on 2015/3/17 22:28:03
VIC DYNO HIRE
Re: Turbo EFI A12 for under $1200.
From Adelaide
Sounds interesting! I'll be watching.
Posted on: 2015/3/11 6:44
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Hawaii, USA
Great idea!
Will you've using $50 GM Flash ECU and $18 cable?
Posted on: 2015/3/11 6:59
From Look who's back in town
Watching to see for l series too simon
Posted on: 2015/3/11 8:12
Was B110 Sedan: L series
Now b310 L series
Hmmm nice
Posted on: 2015/3/11 8:57
Car free
From Central coast NSW
Good to see someone putting some build threads up for the general have a go enthusiasts... Trav hope ur watching this thread.
Posted on: 2015/3/11 10:26
From Creswell, Oregon USA
Where do I subscribe.
You doing a crank trigger or CAS for your ignition system?
Posted on: 2015/3/11 13:31
An idea doesn't work unless you do.
Instagram @MD_Machine
We need more stuff like this on these forums. Looking forward to it!
Posted on: 2015/3/11 20:57
From Melbourne,Australia
Will be watching with interest mate you using the lagwagon as a test mule?
Posted on: 2015/3/11 21:26
1976 120Y 2DOOR SEDAN Z18 TURBO
Check out my 120y 2door sedan here :)
http://ozdat.com/forum/viewtopic.php?f=60&t=9796
Good work.
Did you ever end up selling that a12 turbo motor? You wanted $1800i think?
Posted on: 2015/3/11 22:49
(1) 2 3 4 ... 48 »
