help with extractors
From wodonga, victoria
i am after a good brand set of headers that flow well to suite L20b, any help would be great. and i a prices estimate is available that would be great
Posted on: 2004/6/5 10:04
Re: help with extractors
From Perth Western Australia
i've got a set for my L20b, although i havn't tried them out yet, as i still need to get the engine in. I'll check wat they are... can't quite remeber.
if its to go in a 1200, you can expect to have to modify the trans tunnel. i did on mine...
i don't know if there's any other brands that will fit?
L18_b110... ???
Posted on: 2004/6/5 11:00
clerance is no issue, its not for my 1200 its for the run around sunny, im putting L20b into it but still want it to like the clappers, a good set of headers and some twin carbs and big cam should take care of this.
what company made the headers your using?
Posted on: 2004/6/7 4:59
had another look at them, they're motavator ones (3 MPH 622... dunno what that is, it was below the logo) , apparently pretty good brand
as i mentioned before, i have no idea how well they work as i bought them with the motor that i'm currently putting in (haven't had it running yet). The guy i bought them off wanted nothing but the best, and told me he spent $600 on the carbies (twin su's) and extractors
Posted on: 2004/6/7 9:40
thanks alot for the help might do some research.
Posted on: 2004/6/9 4:14
From Brisbane, Australia
with an L series in a 1200, you'll need custom extractors, or at least modify a set of off-the-shelf extractors.
in the Sunny (310), I would suggest trying a set for whatever donor car you got the engine x-member from.
Posted on: 2004/6/9 4:53
ok thanks, im using the stanza cross memeber becuase i have been told it goes straight in, i dont think the clearance will be a problem at all.
Posted on: 2004/6/9 7:06
From Millgrove Vic OZ
I have a set of used HM21C's ($100) that should be able to fit with a bit of cut and shut by your exhaust shop. PM me for details.
Posted on: 2004/6/10 12:32
Cheers Feral
