« 1 ... 3 4 5 (6) 7 8 »
Re: New Poll: Which engine do you plan to use?
From Adelaide
My 1200 coupe sports sedan that is under construction
is getting a F20C power plant, six speed gear box and a IRS
rear with R200 centre.
Should be a bit of fun once finished
Posted on: 2014/12/4 11:34
Go Fast,
Or Go Home.
From St. Louis, MO
Mazda 13B twin Turbo
Posted on: 2015/4/20 4:39
Puerto Rico! Home of the fastes Rotary engine cars! Period
A great choice. I don't recall that ever being fitted to a driver 1200 bit only to drag cars.
Posted on: 2015/4/20 6:06
From Sydney Australia
One of these would be nice an LZ 16 in a 1200 coupe and the following video after the LZ engined 1200 coupe is the infamous crossflow A series TS Cup car.
https://www.youtube.com/watch?t=3&v=U-8FdizTUOQ
Posted on: 2016/1/17 11:27
Hey that sounds like a flat-plane crank!
筑波サーキットをLZエンジンサニーが激走
http://www.youtube.com/v/U-8FdizTUOQ
Posted on: 2016/1/19 0:22
Posted on: 2016/1/19 4:18
looks like two LZ connected together
Hey what about the Volvo 4.4 60-degree V8, would that fit in a 1200, they did well in supercar, should be less expensive than this one
jpg  FA-RA-RI.jpg (49.75 KB)
174_569dc2ef1db90.jpg 600X450 px
Posted on: 2016/1/19 5:00
would love the volvo 5Ltr version on the superv8s
that is a work of art how they use a modded factory
engine vs all the other custom blocked non factory v8s
Posted on: 2016/1/19 7:22
Well the 4.4 liter is now in the wreckers. Makes 315 hp all-alloy only weighs 419 pounds. Might be smaller than the Rover V8 which has found its way into a few Datsuns
Under $1000
http://en.wikipedia.org/wiki/Volvo_B8444S_engine
Posted on: 2016/1/19 7:36
I think that is factory full spec ready to drop into a Volvo DD but without the power steering, air con and some other pulleys, lightweight flywheel and custom front crank pulley theres another 60-80lbs off there.
http://www.worldcarfans.com/113120667 ... he-v8-supercar/highphotos
nice unit, compact and NA, Nissan should make a v8 like it with 24 degree heads
Posted on: 2016/1/20 5:58
