Head Gasket
From Sydney
i am just putting a new head gasket in my A14. i was wondering if anyone new the torque settings for the 3 stage tightening thing your sposed to do with the bolts, also when i took the bolts out i noticed that one is about a cm longer than all the rest, i was wondering if anyone knew if this will make a difference??
Posted on: 2004/6/7 8:26
Street Tail Dancers
1200 coupe - A14
Re: Gasket
From Melbourne, Australia
it is the same as the a12 Head
Posted on: 2004/6/7 8:35
When the going gets tough the Datsun keeps going😋
Re: Head Gasket
From Perth, West Aussie
yea it has a ring around the number on its head right? it goes in the middle, cant remember what side though, but you will tell as if you put it in the wrong hole it will hit the bottom with about a cm of thread left ;)
Posted on: 2004/6/7 8:38
Re: Gasket
From Sydney
do you know what they are?
Street Tail Dancers
1200 coupe - A14
Re: Gasket
From Hobart Tasmania AUS
6.2kg/m-if it is the same as A12 head
Posted on: 2004/6/7 8:46
1968 1000 Wagon
1967 1000 2 Door Sedan (A12)
1969 1000 4 Door Sedan
1968 1000 4 Door Sedan (parts car)
1964 Toyota Coaster Bus
Re: Gasket
From Sydney
thanks mate
Posted on: 2004/6/7 10:14
Street Tail Dancers
1200 coupe - A14
Re: Gasket
make sure you lubricate the headbolts before you put them in so you get the best clamping force possible from them
Posted on: 2004/6/7 12:24
Re: Gasket
A12 and A14 bolt torque is different. The newer A12s might use the same torque, but not the Datsun 1200 A12.
See Changing Head Gasket.
Posted on: 2004/6/8 5:26
Re: Gasket
From Sydney
two more questions, is there any set torque i need to tension the rocker bolts to and do i need to reset the gaps with a feeler guage if i havent touched the screm/bolt thing above each rod??? if i do does anyone know the gap and how i do it, also wat is the dizzy point gap on an a14?
Posted on: 2004/6/8 12:32
Street Tail Dancers
1200 coupe - A14
Re: Gasket
From Sydney
ok i have the rocker bolt tension now
Posted on: 2004/6/8 12:38
Street Tail Dancers
1200 coupe - A14
