No problem at all.
So, the way the panels are attached.
Is the outer panel, the one you are going to be replacing.
They are sandwiched together, inner and outer, then the spot welds have fused the two panels.
To remove them, you drill/grind the top/outer panel, JUST ENOUGH.
So that the outer panel pops away from the inner panel.
Sometimes you will get a little puff of brown dust, when you have gone far enough.
This is rust between the two panels.
As long as you are just grinding the top/outer panel.
You are pretty safe, it will look rough, However there isn't really a neat way other than slow and steady with the tools.
These spot welds run all the way along the sill,wheel arch, lower rear quarter.
Up the the panel, joining the tail light section, then along the top flange below the tie down rail.
Then past the side vent, inside the door below the B pillar all the way down inside the door frame and back to the sill panel.
They are spaced anywhere from 20mm - 50mm apart
You should be able to see a few of them, the rest are under the paint.
At a guess, there would be maybe 80 or more spots holding the rear quarters on.
Driver side a few extra for the fuel filler area
Once you grind or drill a couple, the panel will pop away.
Watch a few video on YouTube.. There are loads of them.
You need to see, just how removing that little spot is all that is needed.
No heavy handed force, trust me.
It's just TIME CONSUMING!!!!
I wouldn't suggest a chisel or bashing screwdrivers etc..
You will create more work by, ripping the metal on the inside panel.
Which you will then have to try repair and get straight.
Otherwise the new panel, won't fit up nice at all.
Don't want to scare you off it mate.
Its a process, but well worth doing. To know you have near zero body filler and definitely NO rust in your 1200.
Once I figure how to upload pictures I will
