DATSUN 3D AUTO PARTS bike carburetors superchargers turbos efi
Just made this adapter manifold for twin bike carburetors onto 1200, bolt onto standard manifolds. You can actually use the plastic adapter but if i get some good interest for them i will have them cast in aluminium. Linkages will also be available soon
Also have adapter, twin bike carb to amr500 supercharger
Many more projects still to come, and will also custom make one-off parts
www.kemotorsport.com
jpg  a front 1.jpg (20.27 KB)
15999_5559341ddcdec.jpg 700X394 px
jpg  a side 1.jpg (21.32 KB)
15999_5559342c0a19e.jpg 700X394 px
Posted on: 2015/5/18 1:38
Re: DATSUN 3D AUTO PARTS bike carburetors superchargers turbos efi
this kit is just over 3k aud in japan yahoo auctions
which is a rip off as carbs are a 3rd of that
you could make the same manifold but to suit
R1 or R6 carbs or similar CVs
http://page4.auctions.yahoo.co.jp/jp/auction/d165474883
There are heaps of kits that use the amr500 in japan for
modern popular cars as well with a few using custom made
manifolds but ecu controller would be the challenge.
http://page16.auctions.yahoo.co.jp/jp/auction/u75320543
http://page4.auctions.yahoo.co.jp/jp/auction/d163486349
Posted on: 2015/5/18 3:02
What kind of plastic is the adaptor? Fuel resistant?
Posted on: 2015/5/18 3:58
Why would an ECU be a challenge? Bike carburetors don't use an ECU.
Posted on: 2015/5/18 5:33
As far as I know there are no Japanese kits for amr500's, the ones you mention are not for amr's
I like designing with parts that are readily/cheaply available. The bike carbs im using are 34mm, so they are ideal for twin/triple or quad setups.
Adapters allow for cheap setups as you retain your standard factory parts, manifolds...etc
Any setups are a possibility....adapters/manifolds...etc using whatever parts are available.
You want it, there's a good chance I will consider producing it
Posted on: 2015/5/18 7:01
Edited by supercharger on 2015/5/18 7:17:09
DD,
ECU is just in case he uses kits for later cars as there are now plenty of metro kids with little fwd rides that want a simple kit for boost. I Agree keep it simple, keep if for us and keep them carby.
Sounds like a plan, the mini manis would be small and easy to sell in japan for cheaper than those rip off versions. Yeah sorry those chargers are ogura tx.
Posted on: 2015/5/18 10:02
From Creswell, Oregon USA
How well does the plastic hold up to fuels?
Love the idea of printing intakes that would otherwise take some expensive machine work to accomplish.
Posted on: 2015/5/18 16:01
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Adelaide
Depends on the plastic, ABS is not so great with petrol (paraffin solvents), PLA is not so good with ethanol (alcohols). You could paint it with an appropriate epoxy. PLA softens at 60-70°C so not really suited to that type of job. Which is why I'd say supercharger said he'd get them cast.
Posted on: 2015/5/18 21:09
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Drawings done for simple quad bike carb setup, will print soon and design the linkages once the carbs are sitting in the engine bay
jpg  dtc2.jpg (15.78 KB)
15999_555b0106419f0.jpg 700X617 px
Posted on: 2015/5/19 10:24
Manifolds printed
jpg  quad 01.jpg (11.10 KB)
15999_555c315c0e1ef.jpg 700X394 px
Posted on: 2015/5/20 8:01
