laptop freezing
From Goulburn NSW
Hi guys my laptop is freezing,only when its not being used but is on.Its happening quiet often and are wondering whether or not it might be on its way out although it runs perfectly otherwise.Any advice on what may be the problem would be appreciated.
Posted on: 2015/5/23 10:28
Re: laptop freezing
Too much porn
Posted on: 2015/5/23 11:55
Re: laptop freezing
From Adelaide
Is it when the screen saver comes on? For some reason some programs hang when the screen saver comes on. Dunno, just a guess.
Posted on: 2015/5/23 12:38
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: laptop freezing
Quite a regular
From Cairns, Far North QLD, Australia
Eh, When I have problems with my pc I normally run a System restore. when starting up the laptop/pc you can hold either F8 or F12 ( I can't remember) or search System Restore after pressing start button in the lower left corner of your screen if you own a windows pc. follow the prompts and select the relevant date (the closest to todays date) and confirm. All of your files should still be intact (some updates for various programs may need to be downloaded again) and it'll revert your pc to it's last stable state.
Hopefully this helps. Otherwise consider cleaning it out with moisture-less condensed air as dust and other stuff harms the performance. If not take it to a pc store and let them look at it if you don't want to risk damaging it yourself.
Posted on: 2015/5/25 0:58
