A15 initial valve clearance.
Just threw the head on this a15.
Wondering what the cold valve clearance size is?
Is it .014 (.356)???
And for every valve...?
Posted on: 2015/5/31 3:31
Re: A15 initial valve clearance.
From Gold Coast,QLD.
Hot .35mm for both inlet and exhaust
Posted on: 2015/5/31 3:34
SLICK & SMALL IS THE WAY TO HAUL!!!!
Cold and final valve clearance is 0.33 mm for both inlet and exhaust valves. It will be quiet and long lasting.
Nissan recommended .25 cold, followed by .35 hot. But they change their mind several times.
Posted on: 2015/5/31 4:16
What order do I do them in again :')
Posted on: 2015/5/31 7:58
Any order you want.
You can do it with only two turnings of the crank. That's probably easiest. See Valve adjustment.
Posted on: 2015/5/31 9:48
Take off .002" for cold settings over hot.
JD
Posted on: 2015/5/31 13:02
