« 1 2 3 4 (5) 6 7 8 ... 10 »
GX5 Bonnet!
Didn't think I would ever be lucky enough to see one of these ever again. A pretty happy chappy right now!
Posted on: 2015/6/2 8:35
Re: RUREDI'S - B120 A12 EFI Turbo Build
From Sydney
Nicer one. Those GL / GX facelift bonnets are rather thin on the ground these days. They were only around for such a short time, late 1972 through to the end of the b110 sedan / coupe production run in 1973.
Posted on: 2015/6/2 8:59
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
I had one before which came on a GX5 Replica coupe and I was sad to see it go.
Got lucky with this one.
I really want a set of GX5 Coupe Bullet Fender Mirrors but don't like my chances!
Posted on: 2015/6/2 10:45
Finally got my stuff back from Flowcraft.
A15 H89 Head fully reconditioned. Dual Valve Springs fitted with dual valve spring locators. Short turn radius on intake ports cleaned up.
Crank has had oil holes chamfered, oil pins drilled out and taped to suit screw in grub screws, linished and fully balanced.
Rods - New 74mm pistons fitted, rods resized to suit ARP Conrod bolts, bolt seat and slightly up shaft has been shotpeened
Reground Cam and refaced followers.
Had to get my flywheel refaced and order the pressure plate from Dellow (To suit T50) in order for crank to be balanced.
Looking to start assembly this weekend!
Posted on: 2015/6/11 13:14
Edited by ruredi on 2015/6/13 1:53:06
you did go 2mm overbore after all, good stuff!
Posted on: 2015/6/12 3:15
Typo D. It's actually 74mm.
Posted on: 2015/6/13 1:53
Assembly has finally started.
Baby on board
Got a bit messy and greasy in the end but we got there.
Posted on: 2015/6/13 2:06
Quite a regular
From Central Coast NSW
That looks awesome mate, great job.
Posted on: 2015/6/13 5:33
From Nations Capital, Australia
Nice work!
Posted on: 2015/6/13 13:03
GX5 FENDER MIRRORS!!! :o)
A very happy chappy today. Have always wanted these bad boys. Landed today. Genuine GX5 items.
Posted on: 2015/7/3 6:34
Edited by ruredi on 2015/7/3 10:19:03
