« 1 2 (3) 4 5 6 7 »
Re: CHEAP A-SERIES SUPERCHARGER KIT
All 3d parts have been done, will start kit off with amr500 snout extension housing.
These tubes can be cut to size then welded to amr500flange and bearing housing.
Price $80
Extension shafts will follow soon.
jpg  kit p1.jpg (9.62 KB)
15999_5567e4b5835c7.jpg 700X394 px
Posted on: 2015/5/29 5:02
Put me down for one. I will give you a call next week.
JD
Posted on: 2015/5/29 13:12
now available, 6rib flat with v. 140mm od
$140
jpg  datpulley1.jpg (16.90 KB)
15999_5568eb2b1705a.jpg 700X696 px
jpg  datpulley1b.jpg (5.43 KB)
15999_5568eb79d34ea.jpg 334X360 px
Posted on: 2015/5/29 23:43
From Creswell, Oregon USA
DIBS!!
Exactly what I need.
Posted on: 2015/5/30 3:13
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
the way things are going John looks like billet A15 upgrade to A19 - full wet 83mm sleeves and 88mm E16 crank kits will be available in a month!
Posted on: 2015/5/30 3:45
Only 10 crank pulleys available, these pulleys allow you to keep your original v-belt with the option of fittng a blower. You can use the standard amr500 pulley or I can supply smaller overdrive pulleys
www.kemotorsport.com
jpg  datcpulley01.jpg (19.52 KB)
15999_556e62936e472.jpg 700X394 px
jpg  datscpic2.jpg (11.07 KB)
15999_556e6a4c7a774.jpg 323X379 px
Posted on: 2015/6/3 3:15
Edited by supercharger on 2015/6/3 3:45:40
$109 USD?
Posted on: 2015/6/3 14:48
Parler @MDMachine
express to USA $65
pulley with hub $140
total AU$205
send shipping details
I can only accept "family/friends" paypal payment id jverban@hotmail.com
Posted on: 2015/6/4 0:19
Have you managed to do the shaft yet? Be good if I could swing past and get both. Let me know here or send me a text if you still have my card.
JD
Posted on: 2015/6/13 1:56
I should have shafts mid next week, they will be 200mm long so they can be cut to size and welded on to the amr500 shaft adaptor.
The shaft adaptor screws onto the end of an amr500, then a hole is drilled to accept a rolled dowel. Dowel is a safety measure that shears if there's a major blower breakdown
Posted on: 2015/6/13 7:02
« 1 2 (3) 4 5 6 7 »
