« 1 ... 3 4 5 (6) 7 »
Re: A15 Gilmer pulley kit not fitting?
Instead of moving the alternator, look at whether the pulley is all the way back. Maybe it needs a shallower spacer.
To move the alternator
* Use a washer behind the upper (adjusting) bracket
* Slot the bolt holes in the lower bracket, but you might not be able to if it is cast iron. In that case hacksaw or grind a bit off the front off the bracket (where the alternator attaches) and use a washer to take up the slack on the back.
Posted on: 2015/6/3 10:21
Not too shy to talk
From chch
Ok i think i follow that..
will have a look tomorrow
im sure the alternator bottom bracket was like a U and it dropped in with bolt each end holding it in place and be cast iron
Posted on: 2015/6/3 10:48
got a 1979 datsun sunny with a A15 engine in it goes alright
You can also slice the original cast alternator bracket a little at a time and use exhaust manifold washers or similar wide spacers
Posted on: 2015/6/3 12:39
Not too shy to talk
From chch
Is there no easier way of getting this set up to work?
If could would like to not modify factory mounts for if took them off would be easy to put back to normal
Posted on: 2015/6/3 20:29
From South East Brisbane
In the grand scheme of things, shaving the mount down a moving the alt. back is nothing.
Worst case scenario, when you take the gilmer off, just buy another alt. mount for like what, $10, that's what I paid for my last one.
Posted on: 2015/6/4 4:43
datsunikon (fb) | datsunikon (blog)
send picture from the alternator side to see why its not lining up
Posted on: 2015/6/4 6:02
Not too shy to talk
From chch
This is what its like when been running
(Only in garage haven driven it yet)
jpg  20150603_171608-1-2-2.jpg (37.18 KB)
7828_557145788d462.jpg 200X200 px
Posted on: 2015/6/5 7:45
From sydney
Can the crank pulley go on both ways ?
Posted on: 2015/6/5 11:25
AB Car Care Facebook Page
Alignment looks fine except for crank pulley.
Posted on: 2015/6/5 11:45
From sydney
That's what I was thinking . Maybe you can flip the crank pulley ?
Posted on: 2015/6/5 11:52
