« 1 (2)
Re: Rear shocks for a lowered coupe.?
Like I did, diahatsu feroza into stanza crumb. Longer than hilux shorter than stock. stanza stock rear shock similar in length to 1200 shock
Posted on: 2015/6/12 2:11
Quick search says
1200 coupe :
459 mm ext
279 mm compressed
180.59 mm travel
Feroza:
448 mm ext
268 mm compressed
180.59 mm travel
Posted on: 2015/6/12 2:23
Factory service manual says 440 less 180 mm stroke ( = 260 mm).
Diahatsu Feroza first model uses the N43 also.
From the ARB catalog:
Feroza 300: N43 compressed length 295 mm
Feroza 310: N49 compressed length 271 mm
Posted on: 2015/6/12 2:36
Well mine must be n49 then
Shorter
They were about 25 mm longer than the ones I gave crumb
Posted on: 2015/6/12 2:56
That bottom one looks like a Rancho RS 5000 -- great shocks, I had them on my 5.0 Mustang.
Which PN fits a coupe?
Posted on: 2015/6/12 3:13
That brings up an interesting thought: If your coupe shocks are bottoming out, get factory-spec coupe shocks, they are shorter than some aftermarket shocks sold for the coupe. Best to first measure your existing shocks so you can ensure you are buying shorter ones.
Posted on: 2015/6/12 3:19
The bottom are the Rancheros I gave to crumb. too short in stanza. That's why got the feroza bilsteins.
Posted on: 2015/6/12 3:58
From Melbourne, Aus.
Thanks for all the info, looks like im going to have to get off my ass and do some measuring. I will try and do it over the weekend and ill let you know what i come up with.
I'm surprised this isnt a more common issue as i didnt think my car was that low.
Posted on: 2015/6/12 4:29
From Las Vegas USA
I use the Konis mentioned on the first page and my car sits much lower than a treet car would. I think Koni now calls them Koni Classics whereas before they were Special Ds.
Tom
Posted on: 2015/6/13 2:14
« 1 (2)
