« 1 2 3 (4) 5 »
Re: Cheap Stainless steel extractors on ebay
From Sydney
Mattndew76 wrote:
I would like to buy one of these.
The ebay listing says AUS only though.
I'm sure if you made contact with the seller, (John btw) he would probably ship them international .
Cheers
Posted on: 2015/6/22 12:38
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
The money shot! thanks!!!
would be nice all polished up with also a polished supercharger on top!
Looks like a Tomei rocker cover breeding program going on, on 1200.com!
Posted on: 2015/6/22 15:08
From Creswell, Oregon USA
Those look really good.
Whats to going rate on a Tomei cover?
I cant make the CNC version for less than $800 USD.
Posted on: 2015/6/22 17:14
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Matthew
how much would something like this cost
http://www.dsnclassics.co.uk/retrospo ... -rocker-cover-retrosport/
with alloy insert that can be changed at the top like the Courtney eg. to datsun or nissan etc.
http://www.streettrucksmag.com/wp-con ... 2/10/ST-1208-COVER-03.jpg
Posted on: 2015/6/23 4:22
I'm doing some two part rockers right now that will look like the Tomei versions for 500$. USD
Easier to machine in two parts than a solid mass.
Those retro ones I could do but not for what they are offered for. My machine is sloooow compared to new units. So the 630$ USD asking price is about right for a faster mill.
Posted on: 2015/6/23 6:40
Parler @MDMachine
The retro ones in a smooth Tomei like finish would be better
the hinging system and sealing would be an issue? or is there
some kind of stepping that could be used to prevent oil leaks?
Posted on: 2015/6/23 7:46
I see the lunch box hinge as an issue but from the pictures they seem to have a pillow style O ring between the two surfaces. If it locks down tight enough then I see no leaks.
The way I am doing my 2 piece cover is .046" - 1.2 MM groove on both mating surfaces for RTV. Quick easy and no need to source a prefab gasket ring.
I will post photo's in a couple days.
EDIT: It was less expensive to get a full length flat bar of alloy rather than 6 pieces to make some rocker covers. Now I have enough for 4 rocker covers. 2 are spoken for and 2 are not.
Posted on: 2015/6/23 14:28
Edited by Mattndew76 on 2015/6/23 17:41:11
Parler @MDMachine
rather a billet than a Tomei casty
this!
Posted on: 2015/6/25 4:21
That one needs a weld up on the rear inside ledge. Wasn't quite an accurate prototype.. Stock rocker covers are not good for taking dimensions from....
Posted on: 2015/6/25 6:09
Parler @MDMachine
From Lyngby, Denmark
Where do you get those covers!?
Would love one if the pice is okay :D
Posted on: 2016/2/29 18:34
« 1 2 3 (4) 5 »
