« 1 2 (3) 4 »
Re: EGI What are these things on the manifold and which ones are needed?
From Sydney, NSW
Thanks very much David really appreciate the advice. It makes sense
Does that also mean things like vvt can just be blanked off?
Posted on: 2015/7/4 9:28
VVT is part of the EGR. To disable EGR, all you need to do is plug the little hose at the EGR Valve.
Posted on: 2015/7/4 9:50
The crankcase ventilation, if connected to full vacuum, would either suck a vacuum into the crankcase (bad) or create that much flow through the oil filler cap it would run like a pig (bad), or many other scenarios (all bad). I suspect neither of these ports are full vacuum.
I cant put pictures on here as I am not that savvy, but google positive crankcase ventilation.
Posted on: 2015/7/5 6:25
There is no flow though the oil filler cap in Datsun's positive Crankcase Ventilation, all Datsun A12s use a sealed oil cap. You may be thinking of the Datsun 1000, which use passive Crankcase Ventilation and flowed air through the oil cap.
Please read your Datsun owner's manual or service manual, it clearly explains it. The PCV valve itself includes a check valve limiting the amount of air that flows through it. Here's a diagram out of the Datsun 1200 Factory Service Manual:
Posted on: 2015/7/5 7:22
From Sydney, NSW
Hi sorry just a few more questions now that I got the manifold out of storage I was just wondering what did rhey use the water temp switch for in this setup?setup?
http://datsun1200.com/modules/myalbum/photo.php?lid=21839
And is the cotton braided hose here for water?Open in new window
I was just wondering what goes in the threaded hole above. It is missing from my parcel..
This addon was also in the parcel? I assume it's egi related?
Thanks again for all your help!
Posted on: 2015/7/10 13:28
Water temp sensor is an input for the Datsun ECU.
This is the VVT Valve
Posted on: 2015/7/10 13:58
Threaded hole is for EGR Tube fitting. If you don't need to use EGR, just let it be. As long as the EGR valve is in place it will not leak.
Posted on: 2015/7/10 14:04
From Sydney, NSW
Thanks again David! I might see if I can find a short bolt with a thread the same size and block it up
Posted on: 2015/7/10 14:09
Braided hose is probably water outlet. if you're going to use with a dry cylinder head, just leave it disconnected
Compare to Throttle Body, figure "E"
Posted on: 2015/7/10 14:12
From Sydney, NSW
Thanks again! very excited to finally be taking bits apart and getting things working :)
Posted on: 2015/7/10 14:25
« 1 2 (3) 4 »
