Browsing this Thread:   3 Anonymous Users
« 1 ... 3 4 5 (6) 7 »
Re: CHEAP A-SERIES SUPERCHARGER KIT
Hey John, nice work! I was going to route it differently to keep the carby closer to the rhs in the vain hope of not having to buy a new cable. Your thoughts? Is there enough room to run the tubing behind and back towards the master?
Posted on: 2015/7/26 9:41
rear mount carb (CD/SU),standard cable ok to use.
jpg  a12a.jpg (22.95 KB)
15999_55b715eb0232e.jpg 700X394 px
Posted on: 2015/7/28 6:41
From Creswell, Oregon USA
Very cool
Posted on: 2015/7/28 16:28
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
I will call, probably visit Friday as I will be in the area.
Looks perfect.
Posted on: 2015/7/30 9:56
You can use a carter YH carb which was used in Marine applications, turbo corvair and many other cars boats etc. I would use an Ultima R1 carb but these carter carbs are well supported and used on drawthrouh turbo in the 60s.
The lower form factor carb would allow a downdraft inlet manifold tube instead
of going up then down into the charger to avoid pooling and bang!!
http://www.ebay.com/itm/1959-Chrysler ... sh=item463d6ced0c&vxp=mtr
then ultima R1
http://www.ebay.com/itm/NEW-ULTIMA-R1 ... TOR-G-STYLE-/231593766471
then these mystery beauties I cant identify used on swedish bike building
could be carbs or some kind of injection???
http://1.bp.blogspot.com/-YUG44nmxzgE ... r72szk/s1600/IMG_0831.JPG
http://rigidhips.blogspot.jp/2010/06/2000-cc-knuckster.html
Posted on: 2015/7/30 12:22
is there still any of that 120y gear left?
Posted on: 2015/8/10 8:15
last 3 crank pulleys with steel hub available, $140posted
Posted on: 2015/8/17 6:53
DIY AMR500 Gilmer pulley set, 60mm/100mm gives almost 2:1 ration helps to not overspeed the blower.
$120posted
jpg  60100.jpg (8.78 KB)
15999_55d179b3c3f8a.jpg 700X394 px
Posted on: 2015/8/17 7:06
The rear mount one wont fit under the bonnet. If you are going to purchase look at the front mount for the 1200. Obviously the 120y has more bonnet clearance.
JD
Posted on: 2015/9/5 13:34
From Moorebank
Hi Supercharger
New to site, do you have any of the super charger kits, very interested. Thanks
Posted on: 2016/3/16 20:34
