MX5 Engine into 1200 ute?
Hi all,
Over the weekend I was offered a MX5 motor and gearbox. It was removed from a MGA after the guy installing it passed away, the car sold and the new owner wanting the original donk put back in.
Looks quite good size wise, he has fabricated an inlet exhaust manifold, so no EFI to worry about. The box looks small but probably not small enough to fit in the original tunnel (what does!). I have a datsun 5 speed anyway which would probably be OK with an adaptor plate.
Checked wiki with stuff all results.
Pros:
Its RWD, around 100kw depending on year, twin cam, will probably take webers, around the right size.
Anyone done this? If not, why?
Thanks in advance.
Posted on: 2015/9/6 13:26
Re: MX5 Engine into 1200 ute?
Few have done it because few have been given a free engine. Since they buy, Nissan 1.6 (115hp) is a bolt-in to the Datsun 5-speed. Nissan 1.8 makes more power.
The MX5 engine is a good one. You can cut the tunnel down the center, spread it open a bit and rivet a piece of sheet metal over it.
The Mazda 2.0 is swapped into 1200s and can take massive levels of boost when modified.
sub-9 second 1/4 mile runs
626 into 1200
626 engine
Posted on: 2015/9/6 22:01
From Melbourne, Australia
is it 1.6 or 1.8?
i would say for the all the effort involved it's not worth it
you can buy the same series 1.8 turbo motor from a mazda familia for $1200, the non-turbo motors are probably worth less than an A15 and wouldn't make much more power
Posted on: 2015/9/7 0:46
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
But if the price is free, then it's worth it. To make it easy keep the Mazda 5-speed. Mainly needs a custom tailshaft and some adapters for the motor mounts.
Posted on: 2015/9/7 3:43
there is nothing free about that!
in an engine conversion like that ..... the cheap part is the engine!
Posted on: 2015/9/7 5:07
1200 Coupe Rallycar
Thanks guys. Interesting. Im seriously contemplating this!
Posted on: 2015/9/7 13:21
where abouts are you in terms of legalities for pollution requirements?
Posted on: 2015/9/8 4:24
Good point. If the Datsun 1200 ute is 1972 or newer, under Australia EPA it will require meeting the emission standards for the year of the engine (including catalytic converters, etc.) which carburetors will not meet.
Under CALIFORNIA law, any substitute engine requires meeting emissions of the newer engine.
Hence why the A14 is so popular as a "replacement" (not substitute) engine. Meanwhile in other places we enjoy our 2.4 liter 1200s.
Posted on: 2015/9/8 5:26
I think you are better off with a supercharged or turbo A series
if you have the 5 speed already then the rest is patience
A series are easy to refresh if need be and plenty of boost options.
Posted on: 2015/9/8 7:24
You may be right D, just very tempting.......
JD
Posted on: 2015/9/8 12:47
