« 1 (2)
Re: Ute rear shocks - KONI part # ?
Yes. More info needed. I cannot find the right looking VW Passat Wagon shocks online anywhere. I must be looking at the wrong year. I tried from 2006 upwards.
Posted on: 2015/1/4 1:25
anyone ever get this info?
really curious on how to go about my rear suspension
Posted on: 2015/12/23 10:30
Yes
* KYB is Nissan part number 56210-G1000
* KONI never made a ute shock
For a list of other manufacturers, see Truck Shocks
Posted on: 2015/12/23 11:04
would the specs on the UTE XF come close ? curious..
Posted on: 2015/12/29 5:20
Falcon XF Ute specs:
* up to 820 kg load capacity
* kerb weight 1,350 kg
* shock specs unknown
1200 Ute specs:
* 500 kg load capacity
* kerb weight 740 kg
* Rebound kgN 93-127
* Compression 32-50
I suspect the specs are not even close, since it's a much heavier car. Using the wrong spec absorbers mean you loose traction. Usually aftermarket shocks are too stiff so that when you go round curves with slight bumps, the wheels "skitter", not a good thing. Add to that if you are using heavier wheels & tires than stock, it throws the formula right out the window. Solution is to get adjustable shocks like peddars
Posted on: 2015/12/29 8:57
If you don't want to buy the 1200 ute-specific shock (KYB 443066), then I think the custom pedders might be a good way to go! they might be spendy but its something you'll enjoy every time you drive your car
Posted on: 2015/12/29 9:23
From Albury
Part number for Koni adjustable shocks direct replacement is 80-1904
Posted on: 2015/12/29 9:48
Yes, those will bolt onto the 1200 ute. KONI 80-1904 is direct replacement for 1200 Wagon, only the rebound spec is lighter than the ute. May even work better than stock ute type unless you're hauling the full 500 kg
KONI 80-1904
Posted on: 2015/12/29 10:30
So I emailed maddat and asked if they had a koni adjustable rear for the UTE. Not listed on their site, but apparently it's a thing for $380 a pair.
Posted on: 2016/1/26 6:48
From Albury
Ring Toperformance in Melbourne.They should have them in stock.Or I have a used set that still work fine for $250 plus post
Posted on: 2016/1/26 8:07
« 1 (2)
