Ferrari Pistons?!! 77.5 & 78mm
From Las Vegas USA
Over the holiday I was given an A15 & 5 speed out of USA 210. My current A15 is at 1508cc so for this I thought I would try and get a larger bore. I started hunting pistons between 77 and 79mm.
Well lo and behold at 77.5 and 78mm I found some and not for a car I would have expected. Wiseco makes Ferrari 330 V12 pistons in 77.5 & 78mm, pin height is 29.9 and the pin bore is 18.5mm, cost ranges between $123 and $150 dependent on supplier. (Part # 6501M78) Realistically this is not much cheaper than custom ones I ordered from JE a few years ago.
A quick search of EBay finds some used ones between $65-75 range. I may try to get a cheap stock one just to see what's what.
Tom
Posted on: 2016/1/5 6:06
Re: Ferrari Pistons?!! 77.5 & 78mm
Interesting find. A15 compression height is 30 mm only 0.1 mm so those are only short. For effective quench of .5 to .75 you could use a common .6 thick gasket.
$75 each used is still less expensive than new Ross or Venolia custom pistons (about $100 each).
Posted on: 2016/1/5 6:32
Found this photo, if it's the right one it looks like a nice flat-top
jpg  s-l225.jpg (6.04 KB)
174_568b66c147ffa.jpg 225X169 px
Posted on: 2016/1/5 6:46
From Las Vegas USA
That would be it Dave.
On another note I also found Citroen Saxo pistons come in 79mm with a 32.5mm pin height.......A14?
Tom
Posted on: 2016/1/5 6:58
From Mordialloc Victoria 3195
Ferrari Or Citroen?. Which would you rather sprook was in your car?
Posted on: 2016/1/5 7:23
keep it simple
cheaper and higher quality than Italian castings
are Isuzu 4XC1 flat tops which are hard to beat
for a set of 77mm or 1+mm OS versions
http://spanish.alibaba.com/product-gs/4xc1-piston-342081720.html
http://www.ebay.com/itm/CHEVY-ISUZU-1 ... 24-2715-STD-/310573480934
Posted on: 2016/1/5 15:09
Nicer piston design, only problem is those Isuzu 4XC1 pistons are way too short (comp height of 28.5)
Posted on: 2016/1/5 21:11
using an A14 crank into an A12 block 28.5 is perfect as theres no need to mill A15 pistons but on an taller block A14/A15 will suit block with worn, old rusty or warped decks that need machining.
Posted on: 2016/1/6 12:05
