« 1 ... 26 27 28 (29) 30 31 32 ... 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
From Lyngby, Denmark
On thinking of doing the EFI part of this!
But go for an SC12 in stedas it is easier to get legal where i live.
What about fuel? Is this done nu the stock fuel pump of electric one?
+ Ill prop. Go 2/4 injectors, would same setup work there?
Posted on: 2016/1/15 0:37
Stock fuel pump is 2.6 psi. All EFI requires a high pressure pump, at least 14 psi, but usually more like 40 psi.
I'd recommend a fuel pump off a Datsun 280ZX
or a generic EFI pump, like the famous Walbro: $127 and up
Posted on: 2016/1/15 0:42
Okay thanks! I was thinking the same thing, but got confused as I didnt see it mentioned
Posted on: 2016/1/15 3:34
From Ballarat Victoria
Finally back onto this project. Should be ready to test in a couple of days.
jpg  A12 Single inj project turbo manifold.jpg (181.03 KB)
6746_56d03ea2cc202.jpg 581X778 px
jpg  A12 Single inj project Turbo drain.jpg (194.68 KB)
6746_56d03ebf9908d.jpg 581X778 px
jpg  A12 Single inj project both manifolds.jpg (177.31 KB)
6746_56d03ed3733d0.jpg 778X581 px
Posted on: 2016/2/26 12:02
VIC DYNO HIRE
From Creswell, Oregon USA
Super cool!!
Solving the puddle issue?
Posted on: 2016/2/26 16:10
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From gold coast QLD.
Where you putting the actuator Simon?This was actually one of my biggest problems space wise
Posted on: 2016/2/26 21:54
The vapourization issue? I'll just see what its like with the turbo. I do have some ideas to fix it if its still there.
The actuator mount is this mornings project. On Ziggy's, I made a mount that bolted to the underside of the inlet manifold, and lengthened the rod with all thread and a tube nut. I'll post more pics as I progress.
Posted on: 2016/2/26 22:49
VIC DYNO HIRE
Turbo to TB plumbing done. Waste gate actuator next.
It took longer than I hoped, I had to make a 2 bolt flange out of steel to weld to the tube.
jpg  A12 single injector engine,turbo plumbing.jpg (196.71 KB)
6746_56d11cc1e58c0.jpg 581X778 px
Posted on: 2016/2/27 3:49
VIC DYNO HIRE
WG actuator bracket done, Fuel system next. At this rate it'll be going tonight!
jpg  A12 Single inj project WG actuator bracket 1.jpg (195.97 KB)
6746_56d12df180950.jpg 581X778 px
jpg  A12 Single inj project WG actuator bracket 2.jpg (190.76 KB)
6746_56d12e05211e9.jpg 581X778 px
Posted on: 2016/2/27 5:03
VIC DYNO HIRE
Anyone want to guess the KW?
It made 29Kw with the standard engine/carb and ign last week on the test stand. It now has the single injector, turbo(single turbo off the R32 TT skyline) wasted spark ign, E85 fuel and 15psi actuator. No intercooler. It cranked 150Psi in each cyl during a compression test but has never been pulled apart in 35+years. I just hope the old head gasket holds up!
Anyone for a guess???
Posted on: 2016/2/27 5:09
VIC DYNO HIRE
