Thanks for telling us about the Bosch LSU4.2 sensor. They were made famous by the aftermarket A/F Gauge company Innovate, and were quite expensive 5 years ago
searching now I find:
* You can use with dash wideband A/F Gauge
* Haltech can use LSU4.2 with the add-on Haltech CAN wideband kit
* 5-wire Air Fuel Ratio Sensor (wideband 02 sensor)
* $84 diyautotune.com
* $64 Amazon
But actually LSU4.2 are also used by OEMs like Ford, GM, VW, etc. with various connectors
Searching for "Air Fuel Ratio Sensor" they are listed as an O2 Sensor with the key words wide band or Air Fuel Ratio. Some examples:
Bosch 17014 $64 Autozone
* VW Golf 2000-2001 1.8T
RockAuto.com $64 Denso 234-9002
* 2001-2003 Toyota Tacoma 2WD.2RZ-FE, upstream automatic transmission
$91 Amazon
$108 RockAuto.comLSU4.2 is already last generation. All OEMs now use Bosch LSU4.9, but the controller, ECU or gauge needs to support it.
