S13 Brake Conversion Longer Wheel Studs?
Not too shy to talk
Hi everyone,
I am doing a S13 Brake Conversion on my Datsun 1200 ute. On the S13 Brakes info page it saids that you will need new wheel studs that are at least 8mm longer than stock. I bought a set of new S13 wheel studs from Nissan and they are about 46mm in total length. I have acquired a set of Datsun 1200 drum hubs for the conversion and the total length of the wheel studs are about 41mm. On the Wheel Stud info page it saids that the total length of the front disc wheels studs are 32mm. So when stating that the wheel studs need to be at least 8mm longer than stock which measurement is this referring too? the stock disc or drum hubs? Any help would be great.
Cheers
Posted on: 2016/1/28 6:45
Re: S13 Brake Conversion Longer Wheel Studs?
Both
* if you are replacing Drum hub studs, they need to be at least 8mm longer than drum hub studs
* if you are replacing Disc hub studs, they need to be at least 8mm longer than disc hub studs
Posted on: 2016/1/28 7:37
Also note that Drum hub studs differ from Disc hub studs
I suppose you could grind round-head studs to make them fit the drum hubs
Posted on: 2016/1/28 7:42
From Albury
Bursons can get ant size wheel studs you want. I would assume Repco could as well.
Posted on: 2016/1/28 8:10
Posted on: 2016/1/28 8:57
Car free
I use levy as mine
Posted on: 2016/1/28 10:36
Bprojects sells those same wheel studs -- they look similar to the Nismo 51 mm bolts
47 mm long
HKB Sports Racing dress up parts High Power motor sport development
HK34 Nissan 10m8
4 991138 340105
made in Japan by Toei Co., Ltd.
jpg  HKB_wheel_studs.jpg (181.52 KB)
174_56aae20396176.jpg 1280X742 px
Posted on: 2016/1/29 3:52
From northern 'burbs adelaide
Ive used nissan pintara/r31 studs on all the ones ive done mate ;)
Posted on: 2016/1/29 4:20
Yes, R31 studs (Repco S457) fit the 1200 disc hubs. They have a longer shoulder than the 1200 studs, but the extra length of the disc-over-hub (S13 rotor thickness) makes it just right for the S13 brake conversion
Did you use R31 studs on 1200 drum hubs? The 1200 drum hubs use a non-round head stud. But maybe round-head studs will work?
Posted on: 2016/1/29 6:04
Ive only ever done conversions on 120y struts
Posted on: 2016/1/29 6:28
