« 1 (2)
Re: Datsun 1200 Coupe Build Thread *First Time*
zigmondo wrote:
Hey Dave, He called you a Dattomaster -- HEE HEE
ok ok after some browsing on forums i realized that alot of people are datto masters lol
its a rank XD
Posted on: 2016/1/10 15:36
welcome good luck, cool 1200 :)
Posted on: 2016/1/11 11:15
Edited.
Posted on: 2016/2/20 8:57
What is the black thing
Shallots: What is the black thing in the red box, do i need to replace it?
That might be the part (that usually is stuck to the body) which is the foam strip seal, and no it doesn't necessarily need to be replaced, but you might want to
Nissan 63811-H1000 SEALER-front fender
It goes here:
Posted on: 2016/2/20 22:21
Tyre hitting spring
Shallots:
Problem...
I don't recall every seeing that happen before. Maybe the tyre is too wide? Or maybe the struts have been cut short and the lower spring perch lowered way down?
Front Wheelwell - the wheel backspace should be less than 3.5 inches
Posted on: 2016/2/20 22:38
Dremel 250V power plug
Bought a Dremel and got trolled.
That would be a problem here as 220/250V outlets are not common except dedicated to the kitchen oven and electric clothes dryer
But generally speaking there are adapters available, for example:
http://internationalconfig.com/icc6.asp?item=30220
Posted on: 2016/2/20 22:54
@ddgonzal i bought some new tyres for the rims they are like 1cm from hitting, my fronts are 14x6.5
Also with the part numbers how does that work? What website do i search the number on?
Posted on: 2016/2/20 22:56
Clarion radio brochure
i found something really cool in my glove department
That is cool! Looks like an eight-track tape player he's holding
It saysQuote:
クラリオン
サービス店リスト
1972.12.1. 現在 295-0012-00
Clarion
Service Shops List
1 December 1972 Current
jpg  1z6vdqe.jpg (186.76 KB)
174_56c8f235554cd.jpg 1200X1600 px
Posted on: 2016/2/20 23:11
Just saw this:
Those are Nissan part numbers, use the Google web site to search, for example: http://google.com/search?q=63811-H1000
The fender weatherstrip is just a standard piece of foam rubber, buy it from any body shop e.g. call Scott's Old Rubber
Posted on: 2016/10/18 1:12
« 1 (2)
