Fenders
From Datsun 1200 Club
Category: Body
The stock steel fenders are thin and light. A nice compromise. All 1200 fenders fit coupe, sedan, van/wagon and pickup/ute to March 1978. Fenders for USA differ by having larger side light holes.
Care
The fenders tend to rust in two spots: Front lower corner and bottom rear. So wash these spots of dirt, grass and other matter occasionally.
If rolling the fender lip, you might consider sealing the crease:
Front Fender Panel and associated parts.
  • JDM
  • 63100-H1003 ASS'Y-FENDER, front (R.H.)
    • replaces 63100-H1002
  • 63101-H1003 ASS'Y-FENDER, front (L.H.)
    • replaces 63101-H1002
  • 77720-89908 SCREW-FENDER 7510-8503 (16)
    • replaces:
      • 81-106161-1 BOLT, fixing front fender (8)
      • 89-15436-1 WASHER, plain (8)
    Bolts: There are eight (8) bolts per fender: 2 at front (behind grille), 4 along top edge (visible with hood open), and 2 at the back edge (visible with door open). Total of 16 per car, 8 per side.
  • 63810-H1001 SEALER-cowl top [fender] (L=250mm) from 0670
    • replaces 63810-H1000 SEALER-cowl top (L=200mm)
  • 63811-H1000 SEALER-front fender [vertical strip]
  • USA
  • 63100-H1900 ASSY-FENDER,FRONT,RH USA
  • 63101-H1900 ASSY-FENDER,FRONT,LH USA
  • 01111-00022 BOLT-HEX WITH WASHER FENDER FIX (16)
  • 08915-43610 WASHER-PLAIN FENDER FIX (16)
  • JDM Late Truck
  • 63100-G1030 FENDER-FRONT, RH 7804-8012
  • 63100-G1230 FENDER-FRONT, RH 8101-8408
  • 63100-G1231 FENDER-FRONT, RH 8408-8910
  • 63100-G1060 FENDER-FRONT, RH [Square Light] 8910-
  • 63101-G1030 FENDER-FRONT, LH 7804-8012
  • 63101-G1230 FENDER-FRONT, LH 8101-8408
  • 63101-G1231 FENDER-FRONT, LH 8408-8910
  • 63101-G1060 FENDER-FRONT, LH [Square Light] 8910-
  • 01436-00093 SCREW-FENDER 8910- (16)
  • 63810-G1000 SEALING RUBBER-FENDER [top] 7510-8105
  • 63810-G1900 SEALING RUBBER-FENDER [top] 8106-
Fibreglas
The Datsun Competition fibreglass fenders were reportedly heavier than the stock steel fenders. Advantage is that they can be more easily repaired after each race.
There have been some thin aftermarkets, too thin for street usage really, but light.
See Body panels
Suppliers
  • Nissan Australia
  • Nissan Japan
  • Nissan Europe
  • NOT Nissan USA
  • Ocassionally for sale on eBay
  • Showcar BodyParts -- fibreglas and steel
  • ProdBodies formerly Japco - fibreglas hood, fenders, flares, door, trunk, spoiler, air dam
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Fenders"
This page has been accessed 4,025 times. This page was last modified 18:40, 30 July 2012. Content is available under Datsun 1200 Club.
